64 going down
Re: 64 going down
Ya'll are going to have a lot of fun with the wiring! Searching down the circuits that are needed and their relation to the various "nag" devices is lots of fun.
I've played with the Mark VIII's for a long time, and it is not particularly enjoyable even for someone who likes wiring challenges.
Sounds like you are on top of it ,though.
I've thought of integrating the ABS and traction control as well as the factory air suspension sensors. I may end up with F150 ABS to eliminate the need for adding sensors to the MII front.
Do Ya'll intend to stay with the original wheel bolt patterns or modify? I have retained the original 5x5.5 on the front, but don't think I will be able to redrill the rear for that pattern. Easiest out for me is Cobra rear hubs and change back to the MII pattern 13" front rotors.
- Charlie'sChopShop
Re: 64 going down
Toys I'm not looking forward to it the wiring. as far as the rear I just used a spacer/adapter from 4.25" to 4.5" and they also made the rear track centered in the rear wells. You can have your rear hubs re drilled or the also make a kit to drill them your self if that's your thing. I will probably do this down the road as ca$h allows so that I car also run wider wheels.
50adrod Looking good.
Re: 64 going down
fabbed up some seat mounts for the 62 Impala buckets
seats mounted
Mounting the Mark VIII shifter
console rough cutout
seats mounted
64 Build viewtopic.php?f=32&t=31755
- FORDMANLCRACKEL
Re: 64 going down
Looks good. Are u planning on a carb conversion or leaving it EFI?
Lonnie
Lonnie
- FORDMANLCRACKEL
Re: 64 going down
FORDMANLCRACKEL wrote:Looks good. Are u planning on a carb conversion or leaving it EFI?
Lonnie
Never mind I backed up and read the whole thread. lol
Lonnie
Re: 64 going down
Toyz wrote:Ya'll are going to have a lot of fun with the wiring! Searching down the circuits that are needed and their relation to the various "nag" devices is lots of fun.
any tips on the wiring before I get started? I am using the instrument cluster, engine and trans control and cooling fan control. I am using the 64's body harness for lights and wipers. also I had my rear hubs and rotors drilled to a 5x4.5 pattern for $150 much cheaper than cobra hubs.
Re: 64 going down
If you don't have a Lincoln EVTM, I would highly recommend getting one. You have already noted and dealt with the fuel sender incompatibility. Do you intend to utilize the Lincoln message and climate control panels?
Air ride sensors could be repositioned if desired, or that circuitry can be bypassed and removed. A lot of items of the "nag" sort are easily eliminated such as headlamp sensors and controls. There are a few "dual-duty" circuits which will be fun to chase down.
One suggestion would be to find an un-confined area to work while identifying and eliminating circuits; it will take up some room.
In retrospect, if you intend to use the center panels; I believe I would utilize the complete harnesses, then trim in place as wanted or needed.
Re: 64 going down
Toyz wrote:If you don't have a Lincoln EVTM, I would highly recommend getting one. You have already noted and dealt with the fuel sender incompatibility. Do you intend to utilize the Lincoln message and climate control panels?
I was a ford tech for 33 years before I opened my shop and the first thing I did was find an EVTM on ebay, those were the best manuals ever produced, ford quit making them (go figure) not using the message center or A/C controls, most of the underhood harness will be used minus the lights, ABS and airbag circuts. my air ride will be handeled by Accuair so that can be eliminated. there will be way more circuts not being used than being used. any tips on the dual duty circuts you came across?
Re: 64 going down
Sounds like you are eliminating those which came to mind!
Re: 64 going down
Toyz wrote:Sounds like you are eliminating those which came to mind!
thanks
Re: 64 going down
a little more progress
console getting fiberglass
after last coat of glass, just needs finish work
original gauge bezel filled in
Mark VIII cluster installed, this was a ton of work but it came out nice
another console shot
Re: 64 going down
Nice work.Thanks for pics,Tony
Re: 64 going down
How are you fabbing you bed mounts after raising floor?I have been thinking of doing the same thing on my Uni but have not decided to attach body to frame.
Re: 64 going down
62bigwindow wrote:How are you fabbing you bed mounts after raising floor?I have been thinking of doing the same thing on my Uni but have not decided to attach body to frame.
I left the front and rear sill in place and just built a second floor above the first floor then cut out the center section. I will fab up some mounts for the center section, really all that is needed if you do not carry real heavy loads are the front and rear mounts.
Re: 64 going down
molding the Mark VIII shifter trim in place
had to get resourceful it was late and I did not have modeling clay so looked around the shop and found some plumbers putty. it worked.
Re: 64 going down
It's looking good! Lots of ingenuity and work there!
Re: 64 going down
Steering column installed and steering linkage hooked up. it is a IDIDT tilt and telescopic column
custom gauge pods installed just need to finish molding in
accuair e level controller recess installed in console, needs finishing work
Re: 64 going down
Your Truck Is Coming Together Nicely. I Like The Way You Did The Console & Dash Bezel. Also I Really Like The Contour Of Those Seats, They Look Like They Have A Bit More Padding Than The Mustang Buckets....
Re: 64 going down
What are the details on the IDIDIT steering column you used? How long is it vs. the stock one? Was it difficult to install, I'm about to do this with my truck as it gets the Mustang 2 cross member.
