223 dizzy swap help needed
I have been reading info here, ford barn, ford six performance, hamb ect.
Has anyone here replaced the load-a-matic distributor on a61 223 I6, for one that has centrifigal as well as vacuum advance?
What is the easiest cheapest way to do so? I have read info on 300 swaps, but would like a guide for the complete idiot version on the 223.
Pertronix is fine, as well as duraspark so long as it is quick and easy.
Thanks All.
John
Thanks All.
John
Re: 223 dizzy swap help needed
Did I mention quick cheap and easy?
John - I put in the pertronix ignition on my '56 223 6 cylinder 2 years ago and am very happy with the improvment in how well it runs and accelerates. I also have a K&N air filter on it and this past summer I had Daytona Parts restore a spare stock Holley carburator for it. And am very happy with thier product as well. I am planning on getting her out more this comming summer now that it is a lot more reliable. When I did the ignition mod I also put on the recommended fresh plug wires and coil. It runs surprisingly well for the crap they sell for gas now.
'31 Model A pickup, '55 F100 Yblock w/fordamatic, '56 F100 6cyl. 3 spd. BBW my first pickup bought when I was 13 in 1974, '77 Lincoln Town Car with 64,000 original miles For Sale
Thanks for the info, I am putting a clifford performance set up on it and the pertronix i have in it just wont get it.
- bobenhotep
If you have a machinist available you can do it. You will have to have them ream out the distributor gear to fit the 300 distributor. The gear off of a 64 223 is already reamed out to that size. You will also need the 64 223 oil pump because it is 5/16 inch drive, like the distributor.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
Im not familiar with a 223, but there are 2 options that work on a y block.
Take a salvage yard duraspark dizzy and swap the internals. You will have to grind a notch in the 223 housing for the harness.
Disassemble both dizzys and install the 223 shaft on the duraspark body.
Like I say, these are the popular options for a y block.
John, I don't believe the Pertronix itself is limiting performance. If you were to find an earlier non- Loafamatic distributor and install a Pertronix, i believe you would see a vast improvement, especially with a replacement carb.
I did not mean to imply the pertronix was limiting performance.
I am using the 2 barrel from a y block on a 223 I6 and the distributor will not work with the carb.
If I order the 64 gear or find a 64 with a 300, my only problem would be the oil drive?
You would think someone would do a plug and play for people like me.
Not just oil drive shaft but pump unless you can find a step-down drive. You can modify other applications to work, but it would probably take some effort to duplicate the performance of an earlier drop-in distributor. I don't know what exact carb you are using , but all you need is a ported (above throttle blades) vacuum source for the dist vacuum advance. You could tweak one to run just centrifugal advance but fuel economy and cruise would likely suffer.
Paul,
I am using the Autolite 2100 similar to the Holley 2300, on the Clifford set up. They came out of y blocks, I did not want to go to a 4v.
Do you know what years the vac/centrifugal distributors came out of?
- bobenhotep
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
Dan ,
Just found it and read it before checking in.
looks like a winner thanks for all the help
John
John
