Door Handle Shaft Repair Kit
Anyone know if there is a supplier for a Door Handle Shaft Repair Kit? My '65 just stripped out another door handle. Thanks for your help.
Re: Door Handle Shaft Repair Kit
How about a ued one?
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
I'd replace the whole unit. Good drivers side are a little harder to find as they are the ones that wear out.
New would probably be best. Thanks for the help!
I believe the part is interchangeable from side to side.
1961 F350
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
- charliemccraney
If the spline is damaged, which can cause the handle to strip, you can use a triangular file to repair or deburr it.
- bobenhotep
I had a window crank that was totally stripped on my chevy van. I filed it square and used one off of a model a ford. I liked it so much that I filed both of them and the door handles square and replaced all of them. I rethreaded the pin hole so I could use a tiny allen screw. Always a thought if they are really messed up.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
