crown vic swap....oil pan
I have run into a speed bump. When swapping to a CV front suspension, you will need a rear sump oil pan. Come to find out this is difficult to impossible if you are running an FE motor. If there are any leads on 4x4 F100 with FE (rear sump oil pans) I would appreciate it. Thanks
The weathers here, wish you were beautiful.
