Page 1 of 4
my 66 f100
Posted: February 15, 2016, 12:09 pm
by 66redrider
Re: my 66 f100
Posted: February 15, 2016, 12:10 pm
by 66redrider
Re: my 66 f100
Posted: February 15, 2016, 12:11 pm
by 66redrider
Re: my 66 f100
Posted: February 15, 2016, 12:13 pm
by 66redrider
Im in the works of getting a c6 transmission rebuilt that came out of a 76 econoline and once that is complete the plan is to swap it over to the straight 6 which im sure i will have plenty of questions along the way esp with parts buying to make it all work.
Re: my 66 f100
Posted: March 4, 2016, 7:20 pm
by 66redrider
Ok so this month i will be having the c6 trans out of a late 70s ecoline rebuilt and was wondering what else do i need for the manual to auto conversion? Would it also be possible to keep the steering column i have now, 3 on the tree, and just eliminate the shifter handle from it since it wont be needed? Plan on doing a floor mount shifter...any recommendations?
Re: my 66 f100
Posted: March 8, 2016, 3:38 pm
by 66redrider
In the process of changing out the valve cover... havent mounted it uet since im looking for a stainless bolt kit to replace the old ones plus had to order a new oil cap and breather.
Re: my 66 f100
Posted: March 8, 2016, 10:55 pm
by viper driver
great looking truck! really like the satin black interior paint.
Re: my 66 f100
Posted: March 9, 2016, 8:53 pm
by 66redrider
viper driver wrote:great looking truck! really like the satin black interior paint.
Thanks... at first i didnt like it but i think im going to leave it, may give it a fresh coat as a touch up and then add red accents that are glossy.
Main focus is the trans conversion
Re: my 66 f100
Posted: March 12, 2016, 11:33 pm
by 66redrider
Curious on what the best way is to remove the pcv fitting from the old valve cover? Was going to see if i could reuse it with the new chrome valve cover
Re: my 66 f100
Posted: March 14, 2016, 4:36 am
by Geno
Fel-Pro - Valve Cover Grommet Set
Line: FEL | Part # 10740
Found this at the local parts house for less than 3 dollars.
Re: my 66 f100
Posted: March 20, 2016, 7:18 pm
by 66redrider
After ordering a few parts n returning sum, i finally have the new valve cover complete
Re: my 66 f100
Posted: March 21, 2016, 12:13 pm
by 66redrider
Valve cover complete... can start it up tomorrow to make sure all is running right. Also added some spark plug spacers
Re: my 66 f100
Posted: March 22, 2016, 11:18 am
by 66redrider
The transmission i bought a few months back is finally going for a rebuild. Hoping no major issues with the C6, if so then im back at square one
Re: my 66 f100
Posted: March 24, 2016, 9:09 pm
by 66redrider
So was wondering if this plexplate would work for my application of the c6 transmission and L6 motor...
http://www.bmracing.com/products/40332- ... nsmission/
Also looking into this to help with cooling
http://www.bmracing.com/products/70268- ... ery=cooler
And this shifter
http://www.bmracing.com/products/80681- ... &smd=&eng=
Re: my 66 f100
Posted: March 25, 2016, 9:18 am
by jalipke1124
I have the Z gate shifter in my 63 and it works fine, just do not put to tight of a bend in the cable when routing it. I am not familiar with the rest of the products someone will correct me if I am wrong but I believe the flex plate is balanced for each engine, 6cyl, 302, 351 etc. so some more research might be needed. The donor van.. was it a 6 cylinder, that might be a better place to start.
Jim
Re: my 66 f100
Posted: March 25, 2016, 12:00 pm
by 66redrider
jalipke1124 wrote:I have the Z gate shifter in my 63 and it works fine, just do not put to tight of a bend in the cable when routing it. I am not familiar with the rest of the products someone will correct me if I am wrong but I believe the flex plate is balanced for each engine, 6cyl, 302, 351 etc. so some more research might be needed. The donor van.. was it a 6 cylinder, that might be a better place to start.
Jim
Yeag i read up on the z gate and it seems like the best option for the conversion with it being universal.
Yeah i want to make sure i get the right flexplate and starter for this setup. The info i have on the transmission was it came out of a late 70s model econoline van so guess i should see what kind of flexplate they came with.
The trans cooler i feel was a better option than switching out the radiator combo plus saves a few bucks.
Re: my 66 f100
Posted: April 1, 2016, 9:34 am
by 66redrider
So finally got my transmission in my garage....fully rebuilt c6. Now i just have to gather the test of the parts to start the install
While i was out driving i spotted this truck cruisin around the block from my house
Re: my 66 f100
Posted: April 13, 2016, 8:27 am
by 66redrider
Curious....other than air ride what is the lowest lowering kit out there? I seen the 3/5 drop but not enough for me
Re: my 66 f100
Posted: April 22, 2016, 11:19 am
by 66redrider
Is there a good place to pick up the rear bracket for the parking brake, where the rear cables meet the front cable that goes to the handle? I recently thought i popped the cable at the handle but didnt. The front cable came out of the rear bracket. Looking to replace that bracket since its old. Any pictures of how the cables attach at the bracket? Also my handle is easy to pull but some effort to push back in...any adjustments for this? Thanks
Re: my 66 f100
Posted: April 23, 2016, 7:48 pm
by 66redrider
Anyone know where i can pick up the circled bracket? Lmc and summit etc are a dead end. Also anyone know how the cable end hooks up to that bracket?
