gas tanks again..
gas tanks again..
I am researching gas tanks and I know the mustang is popular but the filler is in the bed.. what else is out there that would move the filler out of the bed? a door in the bedside?? that would be fine.. I like Kevins tail light but too much for me.. lol come on guys, throw me some ideas..
Re: gas tanks again..
I mounted a 40 gallon tank inside a flush mount tool box in the bed. Gas, room for as and easy to fill and lock.
Ross Swearingen
1965 F100 "MIKI"
1965 F100 "MIKI"
Why not just use an outside frame setup as per the later trucks? I have put the filler bracketed inside the wheel well, but I don't have to contend with that white stuff, nor filling a muddy truck!
playfarmer
Anthony I put a 49-52 Chevy tank from Tanks Inc. It will fit between the frame rails and the fill is on the drivers side. I got the idea from this forum but I tried searching for it and could not find it. Dave
Now that I have changed the bed of my truck, I too was considering changing the gas tank to a rear mounted one. saw this set up and thought it could work.(Cease Fire- I know its chevy- but its a good reference)
You can see the bed going back on with a slight modification to allow for the fill neck.
Any pics?playfarmer wrote:Anthony I put a 49-52 Chevy tank from Tanks Inc. It will fit between the frame rails and the fill is on the drivers side. I got the idea from this forum but I tried searching for it and could not find it. Dave
A 67 - 72 with auxiliary tanks will fit between drive shaft and frame. Won't be able to install my own until I have the dual exhaust rerouted.
- slixtyfive
One quick comment regarding the 67-72 auxiliary tank option - it will conflict with the park brake cable lever(at least on 65-66, not sure about 61-64)). I started down that path and am still working through that. My truck is a manual so i want to maintain the park brake.
An 84-94 Bronco 2 used a 23 gallon side fill tank. I have one I plan
to use on my 64 and use a side fill door or wheelwell filler with it.
Just my
TR
Just my
Thanks for the heads up. I have a trans brake I can use instead.slixtyfive wrote:One quick comment regarding the 67-72 auxiliary tank option - it will conflict with the park brake cable lever(at least on 65-66, not sure about 61-64)). I started down that path and am still working through that. My truck is a manual so i want to maintain the park brake.
orangeRcode
Like the looks of that tank on the chebby, April.
