Master Cylinder help... 64 F100
Posted: March 14, 2016, 1:20 pm
by Blue64F100
Hello all, new member here. I did a LOT of thread searching and reading before I decided to ask this question, so here goes....
I have a 64 F100 with the 292 and 3 on the tree. I'm using the Speedway Motors disc brake setup in the front, and doing all stock replacement in the rear. So my question is, what master cylinder and proportioning valve have other members used that they know works with this setup?
I'd like a power booster, but it doesn't have to be. And I'd also like something that is a direct bolt on and where I don't have to modify the pedal rod. Does such a booster exist? Can i walk into an auto parts store and buy one?
I'm not afraid of modifying things, but I just don't have much time to work on it, so I'd like to get the most out of my time by NOT having to custom fab things.
Thanks in advance!
Re: Master Cylinder help... 64 F100
Posted: March 14, 2016, 7:47 pm
by tomrooster
Blue,Welcome from NJ I had to shorten mine about 1/2" I used a 78 F150 MC with the power booster and bracketTom
Posted: March 15, 2016, 5:08 am
by lineman1984
Blue,
I commented in this thread about my disk brake upgrade. I used the spindles from a donor 73 F100. The rest of the necessary parts I bought new or refurbished from NAPA (hubs, calipers, M\C, etc). I will never again install a pushrod into an M\C without measuring first. That was the biggest headache of the whole job. Hope this helps!
viewtopic.php?f=1&t=33631
Justin
Posted: March 15, 2016, 8:48 am
by Blue64F100
Thanks for the responses. I appreciate it.
Unfortunately I don't have time to be scouring local yards for a bracket from a 78. And Lineman, judging by your comment in the other thread, and countless others I've read, it sounds like modifying the rod is something I do not want to do.
I am still hoping someone has a direct bolt on dual pot with booster. There has to be something out there that doesn't cost a fortune...
Posted: March 15, 2016, 9:23 am
by Hunter's 64
Posted: March 15, 2016, 9:29 am
by Hunter's 64
http://www.ebay.com/itm/57-58-59-60-61- ... Dg&vxp=mtr
Their ebay store is a little cheaper plus no freight .
Danny
Posted: March 15, 2016, 9:32 am
by HotRodMatt
industrial chassis has a bracket that bolts a ranger booster and m/c to your fire wall. plus it beefs up the general area.
great looking kit. haven't installed on the shop unibody yet but looks great. comes with new pedal and everything
Posted: March 15, 2016, 9:46 am
by Blue64F100
Since you have used these twice, did you have to redrill the pedal or the firewall? And did you use the 7in, 8in, or 9in?
And thanks for the post. That's a great looking piece.
by Blue64F100
HotRodMatt wrote:industrial chassis has a bracket that bolts a ranger booster and m/c to your fire wall. plus it beefs up the general area.
Thanks for the tip. I'll check it out.
Posted: March 15, 2016, 9:50 am
by Hunter's 64
NO drilling required , it bolts right up, I used the 7" to gain as much valve cover clearance as possible.
Danny
Posted: March 15, 2016, 10:26 am
by Blue64F100
You didn't need to modify the pedal or rod at all ?
Posted: March 15, 2016, 7:13 pm
by orangeRcode
Blue64F100 wrote:You didn't need to modify the pedal or rod at all ?
I bought the same one in an 8" booster. The rod is an adjustable one.
Posted: March 16, 2016, 3:55 am
by Hunter's 64
nope.
Danny
Posted: March 16, 2016, 1:29 pm
by Blue64F100
Well then it looks like I found my master cylinder. Thanks guys!
Posted: September 12, 2016, 9:40 am
by jhorst14
Just curious how this turned out? I am looking to do the same thing...although I am going with 4 wheel disc brakes.
I looked at the unit on POL and it looks really nice, however when searching online I also came across this unit from CPP
http://www.ebay.com/itm/57-58-59-60-61- ... 0c&vxp=mtr
Which looked about the same as the POL unit but a bit cheaper. Anyone use the CPP one or know anything about it?
Posted: November 28, 2016, 6:59 pm
by Blue64F100
Jhorst, I still haven't bought a master cylinder. I just got a 460/C6 combo after I found out the 292 I had was junk. I did install the Speedway Motors front disc brake kit and it went on pretty easy.
Now I'm looking into what MC will fit with the 460.
Posted: November 29, 2016, 1:16 am
by jamesdfo
Blue64F100 wrote:Jhorst, I still haven't bought a master cylinder. I just got a 460/C6 combo after I found out the 292 I had was junk. I did install the Speedway Motors front disc brake kit and it went on pretty easy.
Blue64F100: See below, which is copied & pasted from response somewhere up above....
James
Hunter's 64 wrote:NO drilling required , it bolts right up, I used the 7" to gain as much valve cover clearance as possible.
Danny
Posted: December 1, 2016, 8:39 pm
by Blue64F100
James,
I saw that response above. I was just responding to Jhorst question of how it turned out since this thread was originally active in March then went dormant.
Also, I've read that there is little to no clearance with the valve cover with a power booster , so that's why I mentioned I was looking for one that would work with a 460. The original post was for when I was going to run the 292.
I'm trying to avoid buying the MC/booster/pedal relocate kit from Industrial Chassis. It looks like a great piece and I have seen several successful installs with it, but I'm trying to avoid the extra expense of the relocation kit AND then a power booster/master. Know that I mean?
Posted: December 3, 2016, 10:06 am
by bird55
FYI, I'm running discs setup on the front only of my 64/292/3 sp. I DO NOT use a power brake booster but a CCP dual master cylinder. Stops great, don't have to have a booster, IMHO. Cheaper and gives you plenty of room on the firewall. So for the money I'm not convinced the booster is worth it.
