Difference in rear lowering shackles
Blue64F100
Post by Blue64F100 »
All I keep finding is lowering shackles for the 65's and up. Whats the difference between the 65 and the 64 rear shackles?
I want to lower this thing but I keep coming up empty handed.
jkimbrel65
Re: Difference in rear lowering shackles
Post by jkimbrel65 »
nothing I have a set on my 62 works just like they supposed to
Mike
I tried being normal once...
I used lowering shackles for the '65-66 on my '64 with no problems. I had to grind a small amount, about 1/16 off of the shackle mount. It worked fine.
Hunter's 64
Post by Hunter's 64 »
SteveCanup wrote:I used lowering shackles for the '65-66 on my '64 with no problems. I had to grind a small amount, about 1/16 off of the shackle mount. It worked fine.
I did the same thing, but i think i ground the corners off just a little on the shackle :2cents:
Danny
