Exhaust pipe '66 352-HELP!
jefflovesf250s
Post by jefflovesf250s »
Hi all: Can someone post a picture of the passenger side exhaust pipe taken at the join to the manifold showing the joint and the 1st pipe curve (down past the side of the transmission).
My custom exhaust (2.25 pipe diameter) has a 4 inch horizontal section before starting the curve down, and when I tried re-installing the cab, the side of the front support hit the curved section.
Couldn't install cab.
So now need to modify exhaust, moving curved section forward (closer to manifold) so cab will seat on the front support bracket.
Another help would be the distance from the face of the manifold exit to the rear of the curved section.
Thanks in advance for the help. Jeff
MN66
Re: Exhaust pipe '66 352-HELP!
Post by MN66 »
If you don't get what you need, I have my stock exhaust and engine out of my F250 and could take some pics later this week when I drive out to work on it.
Regards,
Corey
1966 F250 LWB
jefflovesf250s
Corey: That would be great. A shot from both the top and the side would be very helpful for repositioning my passenger-side exhaust pipe. Thx. Jeff
jefflovesf250s
Corey were you able to get a pics of the passenger side exhaust pipe coming off the manifold?
Thx. Jeff
tomrooster
Post by tomrooster »
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
MN66
Post by MN66 »
Hey Jeff -
Sorry I haven't gotten out to work on the truck with a couple projects starting at my real job... I hope to get out there tomorrow night but for sure on Saturday if you still need the measurements.
Regards,
Corey
1966 F250 LWB
MN66
Post by MN66 »
Ok,
Not sure if this helps since I have the exhaust out of the truck.
1966 F250 LWB
MN66
Post by MN66 »
Sorry - not much help when I take pics of the wrong side... Didn't notice that someone had already posted what you needed.
1966 F250 LWB
