312 Y block crank, South West Missouri Area
Posted: April 30, 2017, 8:39 pm
by aj64f100390-292
I'm looking for a decent useable 312 crank
Re: 312 Y block crank, South West Missouri Area
Posted: May 2, 2017, 9:56 am
by 64 f100
Why a 312, and not a 292? Several problems with 312 blocks, many being cracked as people re-installed main bearing bolts and cracked the flange the bolt goes in to. If, you get a 312 block and rebuild it, be sure to clean out the main bearing bolt holes thoroughly when you do reassembly.
Posted: May 2, 2017, 10:42 am
by charliemccraney
He's looking for a crank, not a block.
