What did you use to strip the paint?ICEMAN6166 wrote:if you just strip off the existing white paint the panel will be nice and shiny with no need for silver paint
heres a before and after of one i did
My New custom cab cluster and 'stock look tach"
Re: My New custom cab cluster and 'stock look tach"
Hey folks, its Andrew. OrangeRcode brought me over here. I don't have any tachs or vacuum gauges, but I do know someone that does and can get you in touch with him if you'd like. If you are looking for gauge overlays, I make those too, custom or OEM. I've made them for several vehicles and can make just about anything that you can imagine.
This is my setup:
IMG_20160104_140704479_HDR by Andrew Bauer, on Flickr
This is my setup:
- aj64f100390-292
Ya, I know what you mean there...so do you have the same tach or one thats the same size?kelwar wrote:That bothers me too. It's one of the many things on the list of stuff to do, but I figure I should worry about putting my cab back on the frame ...aj64f100390-292 wrote: The only thing that botheres me about the tach is that its slightly smaller than the f800 tach so, it sits right on rhe trim ridge and sticks out.
- aj64f100390-292
Andrew wrote:Hey folks, its Andrew. OrangeRcode brought me over here. I don't have any tachs or vacuum gauges, but I do know someone that does and can get you in touch with him if you'd like. If you are looking for gauge overlays, I make those too, custom or OEM. I've made them for several vehicles and can make just about anything that you can imagine.
This is my setup:
Very nice cluster andrew, and ya by all means get me in contact with him, I cant say I could get one right this second but soon hopefully and thanks for getting back with me on that and getting me in contact with somone who does have one!
- aj64f100390-292
Just remembered you mentioning those overlays..well eventually I may do somthing...im just scared to disassemblewhat appears to be a tach you can take appart..that's a 120 dollar hit..but id love to try.somthing there!Andrew wrote:Hey folks, its Andrew. OrangeRcode brought me over here. I don't have any tachs or vacuum gauges, but I do know someone that does and can get you in touch with him if you'd like. If you are looking for gauge overlays, I make those too, custom or OEM. I've made them for several vehicles and can make just about anything that you can imagine.
This is my setup:
I have the same tach. I wanted the 2 Digit version but ended up with the single because it was about 20 bucks cheaper.aj64f100390-292 wrote:Ya, I know what you mean there...so do you have the same tach or one thats the same size?kelwar wrote:That bothers me too. It's one of the many things on the list of stuff to do, but I figure I should worry about putting my cab back on the frame ...aj64f100390-292 wrote: The only thing that botheres me about the tach is that its slightly smaller than the f800 tach so, it sits right on rhe trim ridge and sticks out.
