Original 15" wheel specs
Posted: February 3, 2018, 9:28 pm
by charliemccraney
In the parts manual, it looks like 15 x 5 was used from '57 until '62. Does anyone know the backspace or offset those wheels would have had?
My truck had newer 15 x 6 installed when I bought it. Those have 4" backspace and work out to about 11-12mm offset.
Re: Original 15" wheel specs
Posted: February 4, 2018, 10:41 am
by Toyz
Charlie, I'm a little fuzzy on this, but 4" backspace on a 6" width would seem closer to a 18/21 mm. positive offset. The old five bolt "innies" were indeed mostly 15"x 5", positive offset was very neutral, in the 5/10 mm. maximum range.
I just packed up all my manuals, I'll look to see if I can easily locate the Hollander for that era!
Posted: February 4, 2018, 11:14 am
by charliemccraney
The width specification of a wheel is between the beads so it is a 6" specification but the overall width is 7 1/8". The center of 7 1/8" is 3.5625", which puts a 4" backspace at .4375" offset which is between 11mm and 12mm.
Posted: February 7, 2018, 3:25 pm
by charliemccraney
Any luck, Paul?
Anyone else have one to measure?
Posted: February 7, 2018, 10:26 pm
by Toyz
Haven't located the manual yet, Charlie, and the general Hollander doesn't list the offsets.
Posted: February 8, 2018, 10:08 am
by Zax63
charliemccraney wrote:Any luck, Paul?
I have a set of innies from a '60 f100 I bought a while back. Unfortunately one of them is slightly wider that the rest. But i'm guessing the 3 that are the same are the correct ones and the wider one is a replacement from something else. These are all bare rims and I can measure them this weekend. I also have two factory innie wheels on the front of my '63 and the spare should be the factory innie as well. The rear wheels on my '63 are later outies that were the previous owners winter tires most likely.
All of these will be for sale around the end of spring if you are looking for a set.
Posted: February 8, 2018, 10:30 am
by charliemccraney
It's important that the dimensions are for a 15 x 5" rim since that appears to be correct, based on the parts catalog. My 15x6s are stamped 15x6. I imagine the 15x5 will be as well.
I'm not looking for a set. What I am doing is considering 17" rims because that allows for so many more tire options, and the tires are generally cheaper, for the same or better performance. The issue with going to any aftermarket wheel bigger than 15" is that there aren't many options below 8" rim width, most of which that I don't consider even remotely good looking, and some of which that are seen on many customs and hot rods which don't interest me because they are so common (like torque thrust). That means more rubber on the road for about the same cross section, which means more effort to steer, which means I need to have the scrub as close to factory as possible while minding clearance to the drag link because I have no plans for power steering. Hence the desire to know what the factory rim offset is.
Posted: February 8, 2018, 5:19 pm
by Zax63
charliemccraney wrote:It's important that the dimensions are for a 15 x 5" rim since that appears to be correct, based on the parts catalog. My 15x6s are stamped 15x6. I imagine the 15x5 will be as well.
Where did you see the stamping at? I have a couple of them stripped and can look. They have the Ford stamped on the triangle part between two of the lug holes. But I haven't noticed any other stampings.
Posted: February 8, 2018, 7:42 pm
by charliemccraney
On the 15 x 6s, it is on the inside of the rim, near the center of the wheel. That one cannot be seen if the tire is installed. It is also stamped on the outside of the rim where the hub cap tangs grab on.
Posted: April 18, 2018, 6:44 pm
by Toyz
OK,old post, but finally found my '64 body builders manual. the F100 wheels in 15 and 16 are listed at .62 offset. I would expect, (but don't know) that the earlier "innies" are the same. That would put the original '64 wheels at the 15/16 mm. range.
Posted: April 19, 2018, 3:28 pm
by charliemccraney
Awesome, thanks. Better late than never.
