4 wheel drive conversions
bobenhotep
Post by bobenhotep »
What axles and other equipment were usually used to make a slick 4wd? When my solid front axle gets to be too much I would like to convert to 4wd rather than go to a modern suspension in the usual sense. Thanks.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
Re: 4 wheel drive conversions
Just unbolt the solid front axle & replace with a 4x4 front axle
The early 4x4 trucks used the same transmission as the 2wd trucks
But had a short (18" ?) driveshaft going to the transfercase
The transfercase had its own crossmember holding it
Then driveshafts to the front & rear from it
There were no short wheelbase 4x4 trucks with a divorced transfer-case , factory.
I would suggest getting a transmission that is coupled to a transfercase out of a
66 or later 1/2 ton 4x4
The rear will need a block between the axle & leafsprings to get it level with front
Brake hose extended & longer shocks needed also (front & rear gears need to match)
Handle assembly will need to be made for inside the cab
Have to make an opening for it in the transmission hump cover
A donor truck with all the pieces will make life much simpler
bobenhotep
Thanks, that's what I was thinking, finding a donor to pull everything off of. I probably won't do the conversion any time soon, but when the time comes, it will be a fun thing to have. New Mexico has literally thousands of miles of trails to explore, and it is almost a waste not to go 4 wheeling. I have the Scout, but a 4 wheel drive Un-Uni sounds like a good way to explore them.
"The Iron Rhino"
-duraspark II/ HEI
greentruck
Post by greentruck »
if using a married transfer case your front drive shaft may hit your crossmember. I have done a couple conversions and this always was an issue.
66 f100 4x4 ,64 f100 4x4 ,65 f100 2wd, 76 bronco, 74 bronco, 68 bronco, 69 mustang mach 1,68 torino gt,42 ford gpw
jeepbut
Post by jeepbut »
Tell me about the Scout!
