Frame Braces
Frame Braces
Anyone have suggestion or leads on part #'s 5050, 5051 and 5135. I can probably patch mine up but if some good ones are available I'd be interested in them. Anyone tried making replacements? Thanks in advance.
Darrell
Re: Frame Braces
After looking things over a bit more, the parts I need are the lower brace parts of the two crossmember in this picture. Any suggestions of have some to sell?
Thanks,
Thanks,
Darrell
Re: Frame Braces
Did you get the braces you needed? If not, I have a frame I will be dismantling in the next month, as soon as I get the cab and box off the frame.
Re: Frame Braces
I think so, but I'll let you know if it doesn't work out.64 f100 wrote:Did you get the braces you needed? If not, I have a frame I will be dismantling in the next month, as soon as I get the cab and box off the frame.
Darrell
