First Drive in over 2 years!
Kansas City
orangeRcode
Post by orangeRcode »
Finally got enough issues resolved so I could put Scarlett on the road. Was only a few miles but felt good to get her out an drive again. Need to sort out the temp gauge issue, paint the bed, install the tach and adjust the timing a bit but should be able to take on a longer shake down run this week before I go back to work on Thursday. Looking forward to the 5+ hour drive to KC from OKC. Glad I have a good buddy following me just in case I have any issues. One other thing, anyone know the trick to getting the key tumbler back in. Currently using a screwdriver as a key!
orangeRcode
Re: First Drive in over 2 years!
Wow, the responses are astounding. :roll:
jkimbrel65
Post by jkimbrel65 »
Good job buddy :rocker: .Looking forward to see it in person.
Mike
I tried being normal once...
Rob, glad to hear it!
As to the tumbler, if you haven't fixed it yet, and replacing with new cylinder, use said screwdriver to rotate switch fully counter-clockwise.
Insert key in cylinder and rotate key to ACC position. Place the lock and key in the switch, depress a pin (straightened paper clip, etc) in the small hole in cylinder face, push slightly on pin while rotating the key counterclockwise. Push the cylinder in place.
If this procedure fails, drive it to Slickstock with the screwdriver, It'll make a good "class project", as compared to, say, removing a wayward transmission!
Mr. Jones
Post by Mr. Jones »
I'm calling shotgun for the first ride.....
orangeRcode
Thanks for the helpful info Paul. Sorry to hear you won't be making it. :(
Dan, you got it! :burp:
Johnny Canuck
Post by Johnny Canuck »
Somewhat sad to see that even this close to Slickstock there is almost no one on here. :(
Great Job Rob hope to see you at SS :steering:
orangeRcode
Looking forward to seeing you there JC! :burp:
Going to work on my truck tomorrow after a dentist appointment. Whittling down the TO DO list. Should be doing a longer shakedown run next weekend.
A "list" sure can be useful
Marking off even the littlest things is a boost
See ya in KC
