What are these for?
What are these for?
Was in the 223 gasket kit I bought for my truck
FarmMotorSports
Re: What are these for?
Post by FarmMotorSports »
Valve and tappet cover seals, the studs pass thru the cover , then these seals, then nuts... they always leaked on my 292 y block...
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
Roger that. That is what I thought but confused by the fact there were 6. Not sure why two extra unless it was for the older style valve cover like I had on the blue engine that was in my truck to start with.
Current engine was out of a ‘60 F100.
Thanks!
bird55
Post by bird55 »
4 for the valve covers, two for the valley cover. on a yblock. Also used on the 223 six and 260, valve cover and side cover.
They don't have to leak if properly installed.
Day 2
Post by Day 2 »
looks like shock rubber???
Fit right into the side lifter cover.
