Thank you. I really do love this truck. I've had it for 35 years.oldsmiley wrote:I enjoy the quality of work you do, and I'm just thrilled that you're really going to drive it. That's what they are made for......
My 63 Unibody
Re: My 63 Unibody
Re: My 63 Unibody
That looks great!
Re: My 63 Unibody
Those lines look pretty nice. Nice work.
Re: My 63 Unibody
Thank you!shipwrecked wrote:That looks great!
Re: My 63 Unibody
Thank you!grump wrote:Those lines look pretty nice. Nice work.
Re: My 63 Unibody
Bummer to have to tear out a 55 year old factory rubber floormat but that's what I did. It was pretty brittle and there wasn't any way to get to the steering column plate on the floor without damaging it. I forgot about the floor in this truck, getting the mat out reminded me of many years ago when I fixed the floor under the pedals. When I bought this truck in 1984 the original windshield weatherstrip had shrunk so much that there was a 1" gap in the rubber, dead center at the bottom of the windshield where the weatherstrip split. Rain leaked in under the floormat and rusted the floor under the pedals. I was in my early twenties when I cut the rusted section of the floor out, riveted in and seam sealed thick, hardened stainless steel in place of the old rotted mild steel.
Re: My 63 Unibody
Would you show what you’re using to bend those brake lines...
Re: My 63 Unibody
I have two benders but this is the one used on the brake lines:Mr. Jones wrote:Would you show what you’re using to bend those brake lines...
https://imperial-tools.com/products/470 ... ng-handle/
The circular loops were hand bent around the handle of my floor jack.
Re: My 63 Unibody
There’s not really anything available to seal the booster assembly to the firewall so I’m making something out of a piece of 16 gauge mild steel plate.
Re: My 63 Unibody
I'm going to pull the steering box back apart. The aftermarket bearings I used were Chinese. I was able to find some NOS 1962 bearings online, still waiting for the bearing races to get here. If anyone is interested, the preload on these bearings is 3-6 inch lbs.(unloaded column), the sector mesh adjustment is 8-13 inch lbs. Worm bearing preload adjustment must be performed first.
Re: My 63 Unibody
I’m going to install a later model plunger type electric brake light switch. The old pressure operated switch was on the old master cylinder. The new switch will be on the pedal assembly. So I made a bracket to hold the switch to the pedal bracket and another bracket that mounts to the pedal arm and actuates the switch.
It’s a PITA to have to make so many items. It eats up a lot of time.
Re: My 63 Unibody
Looks good, I am at same point on brakelines, yours look great. Overall excellent quality of work. I have 390/c6 with what i think is original radiator that ran with the straight 6. I am concerened about cooling ... will see , may have to swap that out.
Re: My 63 Unibody
Thanks, Jeff.JeffinMooresville wrote:Looks good, I am at same point on brakelines, yours look great. Overall excellent quality of work. I have 390/c6 with what i think is original radiator that ran with the straight 6. I am concerened about cooling ... will see , may have to swap that out.
I too was running a stock radiator. The problem is that, with the Trans-Dapt engine swap crossmember, the fan position is down low on the radiator and there is no way to run a stock fan shroud. My stock radiator was very clean inside but wouldn’t adequately cool this truck, especially in traffic and during hot California summers.
