Horn
Jlovett
Horn
Post by Jlovett »
Does anyone have a picture of the horn setup for a 63? Mine is missing and I’m not exactly sure where it is suppose to mount or what the mounts look like. Is it single or dual horns?
Thanks,
Janet
Day 2
Re: Horn
Post by Day 2 »
Do not have any pictures of an original horn, but if I remember right its a single horn mounted on the radiator core ,passenger side, right near the horn relay and voltage reg. Hope this helps, I'm sure someone will know for sure.
unibody madness
Re: Horn
Post by unibody madness »
That location is correct, they came with both a single horn and a dual horn set up they attach to a J shaped bracket on the core support that feeds through a rectangular hole and is held down with a single bolt
Jlovett
Re: Horn
Post by Jlovett »
Thanks for the information it helps.
Janet
