Well the new exhaust valves were installed
New head gasket.. bolts torqued down
Intake & headers back on .....
adjusted valves , started & warmed up
Let cool overnight
Checked header & intake bolts
Rechecked headbolts
Started , warmed up , adjusted valves
Runs v.e.r.y smooth
Kinda disapointed with those huge mufflers
It's just too quiet
Started building the kickdown cable for the c6
Too cold to work tomorow
Guess I'll make a new list of everything that needs to be done
The UNI-KORN
Re: The UNI-KORN
Re: The UNI-KORN
Got the transmission kick-down cable made
Used a steel brakeline tube with an aircraft cable run inside
Made all the fittings so it is very adjustable
Starts pulling at half throttle & is fully extended when wide open
Not the prettiest... but works quite well
Re: The UNI-KORN
The shocks on a 2wd tilt forward
The mounts on a 4wd are on the back side of the axle
If you knock out the rivets
Cut about 5" off the bottom (the 2wd towers are taller)
Drill a couple of bolt holes
Put the left on the right side.....
And the right on the left side....
You can use the stock shock absorbers
Re: The UNI-KORN
Just getting it road ready
I wire brushed & powerwashed the inner fenders
Painted them black top & bottom
Right over the rust holes
Re: The UNI-KORN
The hood was in terrible shape
It had been unlatched & whacked the cab
I brazed up cracks & slapped a can of bondso in it
It has hoofprint dents sll over it .....
but I wanted to see how this paint works that I'm trying
$55 a gallon & they will match color & with hardner should last fairly good
... body is quite rough... this hood will fit right in
Re: The UNI-KORN
Front clip back on ... customized air cleaner....
Hardly doing anything now ... farming starting up
Re: The UNI-KORN
Looking good Pat,I think that Red would buff out and look great....
Re: The UNI-KORN
Nope ... I'm not wasting my time trying to bring it back... if it was original paint , I would consider it , but driver side has been repainted... poorly ... I eventually will put a budget paint job on it
Re: The UNI-KORN
Well …
This one won’t get finished by me
But I sold it to a nice young energetic fellow from Texas
It was a good start
And I will be glad to see it finished
Just have too many things on my plate
And no reason for it to just sit
I didn’t lose any money
Can direct my energy into other projects
It was a good start
Re: The UNI-KORN
Be sure that the new owner keeps us updated on his work!!
It's hard to let them go but sometimes you run into the right person to take on the projects we can't get finished.
