F700
F700
Got a F700
Not sure exactly the difference between this and a F600
Has the Dayton type wheels.....
Not sure if the frame & axles are heavier
F600 trucks are WAY more common (around here anyway)
Plans are to put a 1500 gallon tank on it to haul water or liquid fertilizer
6166 Junkyard Dog
Re: F700
Post by 6166 Junkyard Dog »
Pat basically same as a F-600 little heavier parts on some of them , GVWR'S are rated different and as long as it does not say Super Duty cause that's when things change on the cab F-700/750 is same cab as the smaller trucks where the Super Duties have the bigger front ends, taller roofs, floorboards, Now the Super Duty Hoods will work if you take the filler panel off, glass/rubber/everything that is associated with the cab is the same between those trucks but floor pans and cab mounts have seen different
One thing is great is that the frame widths are the same on a lot of the bigger trucks whether it's a Ford/Chevy/International Etc. so that opens the door on a lot of options especially when it comes to Rear Ends, that's why on my F-600 I have Disc Brake Rear End off a 95 ford Shuttle Bus as well as a Front Disc. + 3.73 Gears in the rear end for that Hwy Speeds
12649
redstone65
Re: F700
Post by redstone65 »
That's beautiful. I almost pulled the trigger on a '68 F-350 flatbed the other day but decided my wife would divorce me if I brought another truck home. "But, baby this one is different. It runs!"
Dave
Re: F700
My wife was on vacation seeing her faminly when this showed up
We were out there a few days later
And she asks "where'd that truck come from ?"
I told her I wasn't exactly sure ... somewhere out west I think
She just rolls her eyes
redstone65
Re: F700
LOL
Dave
04sd
Re: F700
Post by 04sd »
Looks to be in pretty good condition. What engine?
Re: F700
I believe it's a 332
They were a Lincoln Y block used in bigger trucks
Not the same block as the 292 used in pickups & f600s
Re: F700
Low mileage by the look of it Pat, and spent most nights in a shed too.. sad I wasn't there to help drug her home!
Mr. Jones
Re: F700
Post by Mr. Jones »
I’ve never heard of this engine, it must be a Y-block ............
Re: F700
Thats interesting
