this hurt my heart
redstone65
this hurt my heart
Post by redstone65 »
Was driving home from work and just died at a red light. Cranked it back up and it was ok until 2 red lights later and it died again. This time it would crank and start for a split second and then die. Tried quite a few times with the same pattern/result. Seems to be getting fuel, so I'm not sure at this point until I get some time to troubleshoot. Could be the gross GM/HEI distributor I have. Maybe the coil pack on it went out.
I've been towed a million times, but this is the first time for Sgt. Green getting hoisted. [Depressed] :cry:
Dave
Re: this hurt my heart
That sucks. Hope you can get a diagnosis and get back on the road soon!
Sounds like electronic ignition failure
It will soon be back on the road , I betcha !
redstone65
shipwrecked wrote:That sucks. Hope you can get a diagnosis and get back on the road soon!
Thanks April! :)
slick4x4 wrote:Sounds like electronic ignition failure
Thanks brother. Yep, I found the issue this afternoon at lunch. One of the ignition wires feeding the coil had come loose (bad 2to1 crimp). bang.gif
Dave
Thats way better than having to pay a technician $90 an hour to diagnose a 2018 vehicle !
redstone65
Well, what are the odds of this. After fixing the wire and driving to work, it wouldn't crank when I came out to go home. All I got was a click. Ended up being a bad starter solenoid. That solenoid has been fine for the past year and then all of a sudden it dies literally one crank after the other problem is fixed. Truck karma is weird sometimes.
slick4x4 wrote:Thats way better than having to pay a technician $90 an hour to diagnose a 2018 vehicle !
Got that right!
Dave
624WD
Post by 624WD »
Yeah you are right there. Seems like when you have it all licked something else comes up out of the blue and sends you backwards a step or two.
