Info wanted on diesel swap
mongrot
Post by mongrot »
I'm looking onto putting a 242 diesel out of a Ford 6000 tractor into a '62 f100 (I've heard the tractors use the 262 straight 6 gas engines and are a direct bolt in). I know it's been done before but just wondered about the bellhousing pattern. Is the 242 diesel the same as a 215/223/262 pattern or is it an SAE pattern that would require an adapter? If it's the SAE pattern, which one is it and what 4 or 5 speed trans can I use? Thanks
By the way, I don't care about top speed or if the truck ever leaves the farm, I just need it to pull stuff. :mrgreen:
-'61 F100 short box flareside (classic street rod) 223, 4spd
-'62 F100 long box unibody (murdered out) 460, C6
-'66 F100 long box flareside (original) 240, 4spd
-'64 F100 long box styleside (pro-street) 307 GM, 700R4
-'64 F100 long box styleside (daily driver) 223, 3spd
-'65 F100 long box styleside (original) 240, 4spd
-'66 M100 long box styleside (sold) 240, 4spd
-'64 F250 long wrongbox styleside (sold) 292, 4spd
Re: Info wanted on diesel swap
Sounds like a neat project
Looks like if they ran the 223/262 gas
The diesel would run the same pattern
Sure be a neat powerplant with a small turbo
Good torque & fuel mileage my guess
ThinLizzy13
Post by ThinLizzy13 »
https://www.dieselworldmag.com/ford/the ... -tractors/
Sounds like Ford just converted the 223/262 block into a diesel engine. Sounds like it would work and be a pretty neat build.
Blackwaterforge
Post by Blackwaterforge »
