Ok terrible organizing skills have resulted in confusion during reassembly of the rubber cab mounts on my 63. I am reusing the original rubbers for now during mock-up but have discovered I have mixed them up. The only thing I am certain of is the square rubbers were originally on the bottom of the front cab mounts. Other than that I am completely lost. If someone can share the dimensions and locations of the other six rubber pieces, it will hopefully make for an enjoyable day on Saturday(as long as I don't have to go in to work!) This is causing great aggravation trying to semi-locate the fenders and doors.
Thank you all ahead of time!!
61-64 Cab Mount Isolators
Re: 61-64 Cab Mount Isolators
This may come out kinda small but hopefully it will help you......
[img][img]https://i.ibb.co/kDMfDnJ/CAB-BUSHINGS.jpg[/img][/img]
Thank you for the reply but the link will not open anything for me. Do I need to open an account with your image hosting site??
If this doesn't print out too small, it should help you with your request.
Thank you for the re-post! Haven't made time to swap them around yet but hope to get to that this week
