Avery's truck 'The Loud One 2.0'
aarons428
Germany
Post by aarons428 »
Well it has started!! Just picked up a 63 f600 cab and chassis. I haven't seen it in person yet but pictures look pretty decent. I will pick it up this weekend and get better pics.
This will be an adventure!
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
aarons428
Germany
Re: Avery's truck 'The Loud One 2.0'
Post by aarons428 »
13064
13065
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
ohmthis
Post by ohmthis »
Ahh man!!! So what’s your plan?
aarons428
Germany
Post by aarons428 »
This body will be dropped onto a F100 short frame with a style side box. Crown vic front subframe with my old 428 and a c-6 transmission. This is going to be for my daughter who is showing great interest in old trucks.
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
ohmthis
Post by ohmthis »
That will be an amazing project for the both of you! I feel like the memories as well as the truck will be a great way to spend time with your daughter. Keep being a dad man! It’s the best job any man can have.
Very nice truck!! I'm definitely am jealous of the grille and lack of rust! It really is great to see the young ones still attracted to old vehicles. Excited to watch this project progress
aarons428
Germany
Post by aarons428 »
Avery and I tried out the "comet wash" on a few panels and didn't turn out to bad.
13070
We also got Avery's donor frame home and are starting to disassemble it.
13071
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
Jerry D
Post by Jerry D »
Any updates? Surely some progress has been made since your April posting.
aarons428
Germany
Post by aarons428 »
Sorry it's been so long on updates. I'll try better. We have made a good amount of progress. I'll get pictures loaded soon.
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
aarons428
Germany
Post by aarons428 »
Started tearing down the F600 as we are using the sheat metal for her F100.
All the pieces tucked away till we need them.
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
aarons428
Germany
Post by aarons428 »
Time to start putting the engine together. Avery wanted to put this engine together herself! So with a little coaching we got started.
First off Avery honed the cylinders a bit to get a good cross hatch.
After cleaning up after the honing the cylinders she installed the oil gallery plugs and frost plugs.
Next with a little help from wee man (Daxton) she got the crank bearings in and with help from Dad we got the crankshaft installed. Then she torqued down the main bearings.
Time for new piston rings! I did help with this because it just takes FOREVER!! Then Avery put all the pistons in and torqued down the rods. Surprisingly the engine still turns over!!
Now time for the magic stick (camshaft)!!!
Sorry forgot to take pics of the timing chain and front cover.
Now time for the go fast stuff!! PAINT!!! If your an FE purist please don't shoot me for the paint. It's OLD FORD RED. Avery's choice.
We still need to install the head gaskets and assemble the rest of the top end but that will be later this week.
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
Have you found a good box yet ?
Older (61-63) or newer (64-66) style side ?
aarons428
Germany
Post by aarons428 »
We are going to revive a flair side that I've had for some time. It's not the greatest but we will make it work.i just got the metal bed strips today and I know where I can get some free cedar wood to make the bed planks.
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
unibody madness
Post by unibody madness »
Avery is doing great! You are as well, you will never forget this time together.
Encourage her to start a private blog so she can look back on the build.
Maybe she will want to post her own build thread when she is older.
Jerry D
Post by Jerry D »
Nice job Avery! Thanks for the updates, and look forward to more.
aarons428
Germany
Post by aarons428 »
The frame we are using had a dana 44 axle in back and a badly broken rear spring. So we swapped out the whole rear axle and springs from a donor truck.
Next the front axle had to come out and a crown vic subframe went in. It's not completely in yet but it's in good enough for now.
I got a great deal on some 05 Mustang GT wheels and a buddy of mine hooked me up with some free new tires!!
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
Avery is doing a great job. She's going to intimidate the guys with the fact she built her truck herself, Well maybe not the gear heads.LOL Keep up the great work Avery.
aarons428
Germany
Post by aarons428 »
Avery is back at putting her engine back together. This is my old 428 that I had in my 65.
Next step is to put the heads on and get them all torqued down. Avery found out how much it takes to do do this as her upper body was feeling pretty rough by the time she got them all done.
Next step was to install the lifters. Yes I kept them in the same order as they came out. I tried to explain to Avery the importance of doing that.
Avery had fun building the "China rail" instead of using the cork gaskets as they tend to slide out and not seal. The intake was installed right after that. Good thing is is aluminum as it would of taken 20 people to put the stock one back on!! Push rods are also good to install at this point. They are cheap hardened ones ffom years ago as I used to bend them anytime I revved it over 4500 rpms.
So now we put a little bling on it to see how it will look in the truck. Yes I know the wires are not routed right they came with the cap and I will be changing them out before we fire it up!! Now to get the frame ready for the engine and transmission.
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
Those are some cool valve covers!! I've never seen a set of those before. Also what brand of intake are y'all running? Looks like y'all are building for high rpm's.
Great job Avery!! You'll be so proud of all of the work you're doing. Thanks for all of the updates too, helps keep me motivated.
aarons428
Germany
Post by aarons428 »
I got the valve cover at a dirt track swap meet for cheap and they were brand new! They are sold by Speedway motors out of Lincoln NE. I have found they have a "matching" air cleaner lid that I need to buy.
The intake is an old street master 390 that I've had for 15ish years. It's just going to be a street beater truck! Avery is only 14yrs old right now and this will be her engine. This engine has been in the family since 1967!!
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
