300 engine swap
brandonperkins777
300 engine swap
Post by brandonperkins777 »
In my project currently is a 223 six, and I would like to put a 300 in its place. Has anyone ever put a 300 in a '63 before? And if so what did you need to do to make it fit? I know it will require the engine mounting kit for the 300 but what about bolting the bellhousing to the transmission? (which I believe is a Borg-Werner T98) Will the bellhousing require some modification to fit? Any help is greatly appreciated.
Note: I AM NOT interested in putting a V8 in this truck, I would like to stay with a straight six, just not sure if I want to reuse the 223 that is currently in it.
longcabjohn
Re: 300 engine swap
Post by longcabjohn »
Music city trucks on powernation TV are doing a story on a 223, guessing it should be airing soon. I don't know if it will be stock or built.
It might help with decision.
Johnny
Mr. Jones
Re: 300 engine swap
Post by Mr. Jones »
My 66 F-350 has a factory 300, with a straight axle. The engine has a front motor mount… I believe it’s different than yours… that’s the first obstacle finding one…. But the internet has it all… good luck with your install the 300 is an excellent choice
longcabjohn
Re: 300 engine swap
Need to make a correction it is a 262 from a 64. Going into a 60 for someone in country music.
g
