How do you set the time stamp on the posts? Everything else is great, but I would like to set the time stamp so it don't look like this....e73Monday223903
Thanks in advance,
Chop
Post Tme settings
Date Stamp
Chop, have you got it fixed yet? If not, you need to go to Profile and then under Preferences There is an option for the Date Stamp. Mine is set this way: D M d, Y g:i a
Hope that helps!
Hope that helps!
Gene
1961 Intregal cab SWB 223 (getting 302 & TIB)
1969 LWB 302 automatic (Donor for the '61)
2000 F150 XLT SWB (Daily Driver)
mine started doing the same thing.i was playing around with a avatar and i loaded one i go to my profile though and its nothing there other than a box to check delete it.it wont delete no matter how many times you try doin it and thats when my time stamp started doing the same thing his does.
e105Sunday341905
thats exactly the time stamp thats on chops last post.
e105Sunday341905
Ryan
351w/Aod
351w/Aod
61ford wrote:i was playing around with a avatar and i loaded one i go to my profile though and its nothing there other than a box to check delete it.
Sounds like the pic you were trying to upload is larger than 80x80. When I tried loading one on that was too large, it pretty much just reset the screen (like nothing happened), but in the large box at the very top, it reads "The avatar image file size must be less than 24 KB".
I can help you downsize an avatar pic if you need, just shoot me a PM.
With the time thing, have you followed what GLindley said in his post?
If it still doesn't work, better get a bigger hammer.
i went thru there looking for the preferences but couldnt find it i did rem seeing it once though.my time is set gmt -1 and i played around right after time changed with that to get it straight and all was fine until i started messing with the avatar.Thanks ill be sending you a pm id like to know how to resize them,i dont even know how to find out how big that picture is.
Ryan
351w/Aod
351w/Aod
