http://www.speedwaymotors.com/xq/aspx/p ... roduct.htm
No need to go the 57 route Chad!!
Dropped 3" straight axle for our trucks
Ain't cheap but not horrible either, Speedway is only about an hour from me.
- needmoretime
Since we could not pilot one they probably don't know about the hole. Cen-Pen speed shop started machining his own stuff earlier this year. Someone should call John and ask. The earlier axle will work but there is a camber difference that is ever so slight between the 2 axles. Either way thanks to Garbz supplying the donor axle. This as been long overdue.
FYI,
Scuff plates and trim rings came from the same source.
Wayne
FYI,
Wayne
- needmoretime
