63 uni
- ezernut9mm
love that "far out" uni! lol. looks like you have a full plate.
- ezernut9mm
the first one, with the zany 70's side stripe and what appears to be mural art on the back of cab pillars.
u think the outside is wild heres the rest of the piks.
http://fordtruk.com/forums/viewtopic.ph ... highlight=
1963 uni PATINA BLUE
1965 short bed
1965 short bed
little bit more
Front end. Replaced kingpins,tie rods,draglink,wheel cylinders,brake shoes,brake hoses,brake lines and master cylinder.Check out the shocks. Appear to be original. felt good so im gonna try them out.
1965 short bed
1965 short bed
unprogress
putting a motor together is easy. building one right is a pain. getting in a hurry and tried to ignore the deck height. it bugged me to skip a important step in my rebuild. Pulled the heads off to check deck height. they were .043 in the hole. pulled it back apart to get the deck cut. that would have cost me a full point in compression. now I can put it together again.
1965 short bed
1965 short bed
No pressure what so ever, you will get it done in time to spare. Looks really good Ken.62galxe wrote:got the motor back together. now just got to put the truck back together. no hurry. I still got 92 days.
Michelle
- Alan Mclennan
Looking good Kenny!, don`t look up! it say`s 80 days!
Kenny hack it!, bet your life he ken!
Finished up the brakelines, installed the rear brakes, removed the seat and gastank, cleaned the tank out, installed clutch linkage, and cut down the driveshaft and welded it back together. Had to steal the driveshaft yoke out of my 70 torino for the T5 in the truck. Now I just need universal joints. I like the way the banjo fittings worked out on the master cylinder. If you are careful you can drill and tap the bolt for the brakelight switch. Thats it for today and I am taking tomorrow off. You can get a lot done when its only 100 in the shade.
1965 short bed
1965 short bed
- olliesshop
Looking good!!! I have to do my brakes too. The pedal goes to the floor right now, so I'm going to completely redo the system.
Tim - 1961 F250 Uni
X2Michelle wrote:I like the idea of tapping the banjo fitting for the brake light switch.
