Dont have what i thought I had
Kid
Post by Kid »
Well I found a good bell on a 240/300 ( I thought ) that has the tabs on the bell to mount in a straight axle truck. I tried putting that bell on a 302 because I thought they woyuld be the same but it does not work. The top 2 holes line up but none of the rest do. The bell is wider at the bottom than the block. What could this bell be out of. I positivly know it came off a 6 Cyl as I removed it myself and was almost positive it was a 240/300. What do I have . I guess I have no use for it since it will not bolt to the 302 I have so I would like to know what it is if I see someone needing one
jwh f-100
Post by jwh f-100 »
I'm not sure if it's any help but on my '62 with a 300 there is a plate between the engine and the bell. I don't know if that was the norm or something that was fabricated...
Here are some pics.....
http://fordtruk.com/forums/viewtopic.ph ... light=bell
Jason
Beer will change the world.
I don't know how but it will.
Michelle
Post by Michelle »
I don't know but may be it is a bell housing for a FE that you have.
Michelle
Obsa
Post by Obsa »
Kid,
I dont believe that the 240/300 motor was ever offered in the Straight axle trucks. Could it be that the bellhousing you have is for the 223/262 6 motor?
Anthony
Post by Anthony »
Could someone have dropped a 250 into it?? My Maverick had a 250 and nothing fits my 300... :roll: .. Just an idea...
Anthony
banjopicker66
Post by banjopicker66 »
It sounds like it could have been off a 223?
Brian Taylor
Post by Brian Taylor »
I have the bell housing and cover from my 240 if you need one.
1966 Ford F-100 LWB 300
64fordf100292v8
Post by 64fordf100292v8 »
I have the same bellhousing and it was exactly the same way when I put it up to the back of a 351w. Mine also came off of a 240/300. I got it from FordMan thinking I could use it on the back of my cummins 4cyl with the smallblock Ford bellhousing adapter but no dice. :(
Obsa
Post by Obsa »
Maybe I am wrong, but I thought the 240/300 had the same bolt pattern as the 289/302/351W motors
Hawkrod
Post by Hawkrod »
Yes, all 240's and 300's have the same bellhousing bolt pattern as the 289/302/251W. If the bell you have is off of a 6 and does not bolt onto a small block it is probably a 223 style bell. Many people do confuse them. Hawkrod
Kid
Post by Kid »
Well I am positive it is not from a 223 as it is no where close to the one I have on the 223 going in my chop top. I had planned on using the 302 I have with a 4spd in the 64 but doesnt seem to be working that way. I will see if I can get some pics and measurements since I cant seem to be able to use it maybe somebody else can figure out what it fits and have a use for it........
Obsa wrote:Kid,
65-66 Big Slicks - F 350 & up had this mounting and a big six.
Obsa
Post by Obsa »
:oops: I didn't even think about the big trucks. My bad, at least I learned something. Was there a larger six just for the big trucks?
300 6 was the only 6 in the medium duty trucks.
the 4x4 and f350 from 65/66 used the bell with ears.
i have one, never tried it next to a 302/351 so i dont know the fitment issue.
i do have other later 6/302/ bells that i could compare to.
theres a part # in the casting , will look at the one i have and post later.
Kid
Post by Kid »
where is the part number in the casting Brian.
Darrell
part # is on the trans side face
Kid
Post by Kid »
WOW I have been IMing with Hawkrod and he thinks the bell I have is from a Diesel engine. I may have to srart looking for the one he said it is from and see if I can do a conversion on the other project I have, or how about a Diesel powered chop top Thanks Hawkrod for all your help, I appreciate it
thats a possibility i did not consider.
perhaps Michelle has some info on the diesel bells.
