1964 f250 divorced transfer case ?
rick heisler
First let me say hello guys I m new. case?Does anyone know if a 1968 429 super cobra jet will hurt my original transfer? ANY HELP WOULD BE GREAT###
rick heisler
I built this motor with about 520hp I know its way to much but once I started it was like an ediction where do you stop? This truck will never see offroad again so I hope if I dont drive it like I stoll it MABE IT WILL SURVIVE##### thanks
Anthony
I think that there were two choices for divorced transfer cases Np205 and Dana 24. Both are about as strong as anything ever built The 24 has straight cut gears and whines in low range. The 205 is easier to get parts for and is generally the desirable choice. But who knows what is hiding under your cab!
Tech
Tech
Welcome to Slick 60s.
- Roger Carter
you are far more likely to break a u joint in the drive or axle shafts than break the t case in a gear driven case.
chain drives i dont mess with after i broke a chain one time.
rick heisler
Hi guys thanks for the info I live near Sarina Ontario I am hardly ever home so this project will take awhile but I know my son enjoys just spending time with me and that old truck
- 65f100_Thug
- 64fordf100292v8
rick heisler
1964 F250 DEVORCED TRANSFERCASE
i HAVE REPLACED FRONT AND REAR AXESL WITH 1970 DANA 44 8 BOLTS
