More paint questions
Uncle Skip
Post by Uncle Skip »
Just researched and found that I can thin my PPG epoxy primer and use it as a sealer.
But some of the guys in the paint forums are saying I need to shoot the color while the sealer coat still damp/ wet.
I don't want to or have the time to do that.
Can I let the sealer coat cure, scrub it with a scotch-brite pad and then shoot the color?
We're talking components here, not the entire truck.
Thanks guys.
U@ss
Max
Post by Max »
Sealers have to have 'bite' for the paint to adhere to. It should tell you what the re-coat window is. Normally if you miss the re-coat window, you have to scuff, re-shoot sealer, then topcoat.
ronk16
Post by ronk16 »
sealers usually have different mixings procedures.......3:1:1 for primer, 3:1:1:1 for a sealer, the third part being a tint for proper coverage, sealers also use slower hardner along with a different reducer for flash times. temp and moisture will also make a big difference in you end result, mix accordingly.....
Skip if your using DP epoxy primer it can indeed be used as sealer. Using DP402 catalyst you allow 15 minutes before topcoating @70 degrees,allow 30 minutes if you're using DP 401 catalyst.
Just a thought Skip,
buy a Harbor Freight gun for sealer. Your good gun for color. Mix them both up, spray the sealer and then pour the color in the second gun and shoot when ready - you can clean them both after shooting. Shouldn't take more than an additional 20 minutes that way?
64low-n-slow
Post by 64low-n-slow »
Skip,
You should have no problem letting DP 40 dry, then scuff real good and shoot. Especially parts.
The company I work for has a couple epoxy primer / sealers that give you 4 days to re-coat. Not inexpensive, but handy.
Good luck
BB
unibodyboy
Re: More paint questions
Post by unibodyboy »
Uncle Skip wrote:Just researched and found that I can thin my PPG epoxy primer and use it as a sealer.
Thanks guys.
U@ss
Skip,
Probably too late, but thought i'd throw some stuff out there.
You can let it cure and not scuff it with scotch for up to roughly 48 - 72 hours depending on weather and thickness of the coat (s), you probably need to hit it with a light scuff.
Just curious, but are you using DP or MP, and are you spraying on bare metal?
Greg
Greater love has no man than this, that a man lay down his life for his friends. John 15.13
