Anyone here install a 3G alternator on their FE?
qwertyd10n
Post by qwertyd10n »
Good morning,
I'm going to want to put a little better looking alternator in my truck when I install the brand new, shiny 445 in it (my beat up old unit just won't cut it). So, I've been doing some research into alternators the last few days.
There seems to be lots of proponents for the 1 wire alternator conversion, but I'm not sure I want to go that direction. A Ford 3G unit however, sounds like something I'm interested in. There doesn't seem to have been much discussion on this topic given on this forum given my searches, so I'm looking for input if anyone has any.
If known, which 3G alternator off what car would fit the top mount FE location without mods? Large case or small case? Amperage recommendations (I was thinking somewhere between 95-130)?
Cheers,
Dion
oldfordcoupe
Post by oldfordcoupe »
i installed a 3g on my 77 bronco and also on my 46 coupe and i put one on my 65 slick you can turn the back to put the plug in ant of 3 position
+ they work real good 130 amp. off of a mustang on a sable or such
Uncle Skip
Post by Uncle Skip »
Dion. I hung a mini 130 amp one wire unit under the bracket.
I did have to make an arm for adjusting the tension by welding two together.
[albumimg]8859[/albumimg]
Its been working great for a couple of years.
U@ss
Effie
Post by Effie »
You might be able to find something on Ryan's website - FordFuelInjection.com.
I'm probably doing the 3G thing on the 429 in my Bronco. Hadn't thought about it for the FE though.
~/\/\elissa~
Image '66 F100 -- Little Black
Image '78 Bronco -- Brutus
Johnny Canuck
Post by Johnny Canuck »
I put a 2G on Jinx. Was easy, just found an 80's ford truck in the yard and grabbed the harness too. The conversion is well documented for 2g and 3g on the net. Didn't need to change any brackets, and the ammeter worked. You couldn't say that with a Delco.
Jonas
Post by Jonas »
There are a couple wring diagrams here.
http://forums.vintage-mustang.com/mod-c ... tions.html
I might consider this.
1966 F100 SWB 390/Toploader/Ford traction Loc
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
