Course there's a couple other ways a Chebby can make ya stop. You can put one of their mills in your truck. The truck will hate it so much it will just stop, as will all bids on ebay. Or, you can get a Chebby block on a chain,and throw it in the box. Then when ya really need to stop, you can just toss anchor.
Brake anxiety
- Johnny Canuck
As I recall they use Ford rotors in that swap, Willy. If a Chebby can help ya stop better, I suppose it can be overlooked. After all, one of the main wearers of the Saffron robe around here, Our Uncle Skip, has placed his blessing on this swap, and indeed has it himself..
- FORDBOYpete
Everybody has opinions, but opinions based in fact carry more weight: Nothing Stops rotating mass with velocity behind it like disc brakes.
Can you imagine an F-18 Hornet with drum brakes?
Can you imagine coming to a safe, controlled, straight, qwik, stop after a 12.60 sec pass thrugh a 1/4 mile at over 120mph in your Slick?
If drum brakes work so good why don't things that must absolutely stop quickly and safely with complete control use drum brakes, like those I mentioned above?
It's mathematically absolute, Disc brakes stop moving things better and that is NOT
Power Front Disc Brakes with a proportioning valve for the rear drum system is the best brake set up fpr a vehicle being driven in traffic at speed and that's a simple fact. And I hope that all those behind me who entertain a different opinion have great Insurance or a good Attorney.
We are currently in the 21st century already doncha see? Roads are crowded, people suck at driving, and most do not care. Their emergency plan seems to be to white knuckle it all the way to impact. I need more than a St. Christopher medal and a prayer.
Disc brakes give me options, just like progressive suspension, anti sway bars and mega huge POWER all give me options too
FBp
Change is the Only Constant
shawns fords
FORDBOYpete wrote:Disc brake upgrades are a bunch of Bovine excrement ?
Everybody has opinions, but opinions based in fact carry more weight: Nothing Stops rotating mass with velocity behind it like disc brakes.![]()
I have a friend with an old mopar he upgraded to a 6 piston wilwood kit 1500 bucks down the drain, wont stop any better than the old drums do, and only lost 8 pounds of weight instead of the 12 lbs they claimed to do
Drums are not heavier than disc brakes, you need drilled high performance rotors just to lose any weight at all
Can you imagine coming to a safe, controlled, straight, qwik, stop after a 12.60 sec pass thrugh a 1/4 mile at over 120mph in your Slick?![]()
yes you can lol its called keeping your shoes adusted
the reason is ease of assembly, not the fact they are "better"
It's mathematically absolute, Disc brakes stop moving things better and that is NOT. . . It is fundamental physics 101.
it is Bullshit, yuppies love to tell their pals they upgraded to disc brakes
lets put my power drum brakes up against an exact same car with power disc, my 2006 F150 four wheel disc cant stop any better than my worn out 78 F150 with front disc and rear drums, hmmmmm as well I can stop on a dime in my four drum 67 and 69 mustangs like I said before NEVER HAD A PROBLEM
We are currently in the 21st century already doncha see? Roads are crowded, people suck at driving, and most do not care. Their emergency plan seems to be to white knuckle it all the way to impact. I need more than a St. Christopher medal and a prayer.![]()
Disc brakes give me options, just like progressive suspension, anti sway bars and mega huge POWER all give me options too.
FBp
