clutch vacuum leak?
TX, OK, AZ, LA, NM, AR, CO
Danimal
clutch vacuum leak?
Post by Danimal »
Good Morning!
My 66 SWB I240 3 on the tree is making a noise when clutch is engaged, and still a little while not engaged.
It sounds like leaking air, but not a whistle or anything. Just like a "ssshhhhhhh" noise. This sounds is very noticeable while clutch is engaged.
This is my first Slick so I'm not real familiar with the set up. It seems to shift fine, and the clutch works. Just that loud noise.
Any idea what it could be? Vacuum?
Thanks! :cheers:
The weathers here, wish you were beautiful.
Mr. Jones
Re: clutch vacuum leak?
Post by Mr. Jones »
Do you have a vacuum booster?
Danimal
Post by Danimal »
dwjones, I do not think so. Where would it be located?
Mr. Jones
Post by Mr. Jones »
it would be on the fire wall behind the master cyl. A large round black thing.Also, any sort of vacuum leak will cause your engine to preform poorly. How's your idle?
Danimal
Post by Danimal »
My idle is bad. Also when trying to drive it sputters a lot. However this comes and goes. Glad you brought it up, I have replaced all pugs, rotors, cap, wires, new fuel line, fuel filter, ignition coil....yeah everything trying to figure this out.
I will see if I can locate the vacuum booster.
Dumb question, will the noise be coming from the booster if it's leaking?
Thanks!
Mr. Jones
Post by Mr. Jones »
Get yourself a length of flexible tubing,one that will fit into your ear,listen for a leak around the base of carb and each intake port,if any are found tighten up the bolts.If you do have a brake booster and it's working properly your brake pedal will depress slightly on start up,if not you should have a very stiff pedal all the time.another thing to check is the vacuum advance,remove your dist.cap and rotor,disconnect the vacuum line ,if rubber slide it off the steel line.If it goes to the carb. do it there.Next,and excuse the phrasing,suck on it really hard,you'll be looking for movement inside the dist.If you see something move you're good there.
Danimal
Post by Danimal »
Thanks a lot dwjones. That is great info. I will try it out this evening and update with my findings.
Thanks again!
Danimal
Post by Danimal »
dwjones you were right on the money. My distro is shot. I opened the cap to perform the "sucking" test.
I noticed that the spring and pin were broke. So I will replace the entire unit. I was thinking abut installing a Duraspark II from a ford Fairlane, do you it that requires anything special to install? Or is it a direct fit?
Mr. Jones
Post by Mr. Jones »
Just saw your last message,I'm not sure about mixing parts.Check out the work that Bobenhotep has posted about the dura-spark,he seems to know a lot about them.Where do you live in the southwest?
Good luck
fmartin_gila
Post by fmartin_gila »
Sounds like it's coming from under the dash around the pedals? More than likely the brake booster is going bad as the air intake for the booster is where the push rod goes through the firewall and is where you will hear the "whoosh"/
Fred
Danimal
Post by Danimal »
Yeah that is correct Fred. Only thing is I don't have a brake booster.
Any thing else it might be? :dontknow:
62galxe
Post by 62galxe »
throwout bearing
1963 uni PATINA BLUE
1965 short bed
Danimal
Post by Danimal »
Ah okay. I will check that out, thanks 62galxe.
