64 going down
50adrod
Re: 64 going down
Post by 50adrod »
-=GS=- wrote:What are the details on the IDIDIT steering column you used? How long is it vs. the stock one? Was it difficult to install, I'm about to do this with my truck as it gets the Mustang 2 cross member.
it is 19 inches long, I was going to have clearance problems with the exhaust so this worked best for me. my universal is in the cab before it goes thru the firewall. I had to fab brackets to mount it. the stock column goes all the way thru to the frame mounted steering gear
50adrod
Re: 64 going down
Post by 50adrod »
a little more progress, the new rear rims came in and working on the widened and raised wheel tubs
American Racing Torq Thrust M 18x10 6.5 backspacing 295/35/18 BF Goodrich KDW's
old wheel well out and floor modified for clearance
new wheel well inn need to make a filler panel to the bed
big ole wheel and tire fully tucked
62bigwindow
Re: 64 going down
Post by 62bigwindow »
How did you fab the steering column mounts?I am going to have the same issue with my truck.
50adrod
Re: 64 going down
Post by 50adrod »
62bigwindow wrote:How did you fab the steering column mounts?I am going to have the same issue with my truck.
made the brackets and used an ididit floor mount bracket, then modified the stock column mount
a piece or 4 inch flat bar and some angle iron. it is just tack welded now I will finish welding when I pull the brake pedal housing out to modify the pedal, I hate overhead welding. I will also use carriage bolts for a finished look.
50adrod
Re: 64 going down
Post by 50adrod »
wow, did not realize how rough those tack welds looked. I will also remove all the set screws and drill and thru bolt the universal. I have had those back out before.
50adrod
Re: 64 going down
Post by 50adrod »
one wheel tub widened 3 1/2 and raised 1 1/2 inches. (what a pain) also cut the cypress bed wood
Rusty 63
Re: 64 going down
Post by Rusty 63 »
That's what I love about the IRS - lay it on the ground but you still have a "real" bed! Nice work.
50adrod
Re: 64 going down
Post by 50adrod »
todays update, the front air suspension is in, the truck will lay the frame on the ground but also will have 9 inches of clearance at the rockers when in the full up position.
50adrod
Re: 64 going down
Post by 50adrod »
rear roll pan modified and test fit
Sweet6T6Ford
Re: 64 going down
Post by Sweet6T6Ford »
Ive really enjoyed watching this build come along... keep up the pictures. Cant wait to see the end result. i would like to do the irs as well but that will have to be on the next truck.
Robert
http://s1231.photobucket.com/albums/ee512/uofmfresh/
"In the silence of the night if you listen quietly you can hear your neighbors chevy rusting"-- unknown
50adrod
Re: 64 going down
Post by 50adrod »
here is todays update, got the shock mounts made and the accuair height sensors installed then installed the front sheetmetal. I cut the radiator support from the donor Mark VIII (nice to have a donor for parts) and will use it for the radiator and condenser mounting, this will work out good. I will have factory radiator and a/c condenser with factory cooling fan. the trans cooling lines will mount without modification also. I did not realize how low the radiator is mounted in the Mark VIII, I had to remove the front crossmember but with the mustang II crossmember welded in and the frame boxed it should be fine. I will make a filler panel above the radiator.
accuair
crossmember removed
donor section of radiator core support
radiator and fan mocked up, it will use all the stock hoses
Sweet6T6Ford
Re: 64 going down
:clap: Looking awesome!!!!
Robert
thenephilm
Re: 64 going down
Post by thenephilm »
Hi I'm Justin.
1965fordf100
Re: 64 going down
Post by 1965fordf100 »
Looking great! Do you have more pics of how you did the structure for the bed floor and how it attaches to the truck frame?
Phil
50adrod
Re: 64 going down
Post by 50adrod »
1965fordf100 wrote:Looking great! Do you have more pics of how you did the structure for the bed floor and how it attaches to the truck frame?
I will look for some, It is one inch tubing welded to the original bed floor and sides, the section in the rear for the fuel tank is the only part attached to the frame
50adrod
Re: 64 going down
Post by 50adrod »
thenephilm wrote:Lookin nasty sir. I like that you are running an accuair setup nuts.gif
thanks, the accuair is a sweet set up
totten
Re: 64 going down
Post by totten »
Great fab work and thanks for the pictures
Re: 64 going down
50adrod, what height and diameter are your rear bags?
Thanks,
lo6fo
Re: 64 going down
Post by lo6fo »
Any progress?
64 f100 long bed 292 with a 4 speed
50adrod
Re: 64 going down
Post by 50adrod »
lo6fo wrote:Any progress?
it is on hold while I build my 54 Cadillac Limo restomod. but I will getting back to it
