Will this PS Bracket Work?
bruceandersson
Re: Will this PS Bracket Work?
Try it an see if the pump lines up with the crank pulley.
- Roger Carter
Ford made a lot of different power steering pump brackets for several different engines that look similar to the one pictured.
If possible, try it and see if/how it fits.
Good luck.
Good luck.
Roger Carter
