The doors on my Unibody are from a regular cab, they don't fit very well. the upper back corner has a big gap and the top of the door hits the cab and doesnt want to shut all the way. I have tried to adjust every way possible but tweaking one way just seems to upset the other.
thanks
Uni and regular cab doors the same?
DaneW1962Uni
1961 Uni LB
1962 Uni SB
1941 Dodge 3-win
1950 Hudson FB Coupe
1953 Hudson Hornet
1936 Ford "Roadster" Pickup
1941 Chrysler Club Coupe
1936 Ford 4dr Sedan "Gasser"
**WANTED-- 1941 Mopar frame**
1962 Uni SB
1941 Dodge 3-win
1953 Hudson Hornet
- 66fordtrucknut
- jimbob1021
Body lines are definetly different,the uni has a body line that goes down on an angle and the reg. cab lines are straight,would not look good.They will fit though. You usually have to make either one fit good as far as the gap. I welded and ground on mine to get them to fit a decent gap the same all around. Drilled tapered pin holes in the hinges after I got them fitted,so I could take them back off and paint them. Merle
1966 F-100 "Grabber Blue" Pro St. [ 99 to 44/100% pure recycled FORD ]
