https://images.search.yahoo.com/images/ ... =yfp-hrmob
From what I have gathered in my search the 67-69 used the same block for disc and drum. The picture is of a 4 drum system. On the disc #3 port (pictured) would have a plug and a single line ran to a brass block that splits the front. There is a D0ZX-XXXX-X that was used late 69(?)/70 through the 80's.
I am looking for a bolt up deal. In my opinion the $150 N.O.S. block is a little ridiculous.
Thanks For The Replys, Here Is A Photo:
- unibody madness
Re: Thanks For The Replys, Here Is A Photo:
That's why I posted about p'n p', that block simply splits the flow with an indicator light, if you hook it up, when you lose pressure front to rear
Started a new topic by mistake. I went a head and bought the N.O.S. block. Nothing wrong with shopping at the wrecking yard, it is just not what I am doing right now. Lots of work to do yet.unibody madness wrote:That's why I posted about p'n p', that block simply splits the flow with an indicator light, if you hook it up, when you lose pressure front to rear
Glad you got it sorted out..
- 6166 Junkyard Dog
I am missing something here cause you cannot mix up valves from trucks without disc and ones with disc. trucks without disc has to have pressure on all 4 wheels and trucks with disc brakes has pressure on the rear wheels only now also if the trucks 67-72 with disc. has 2 valves one under the cab and one under the engine saddle,, right now cannot say on 73-79 F-250's since not at the shop and sometimes research on web can be wrong,,, all 73/79 F-100/150's only have one valve so what I am missing and of course you cannot mix up master cylinders since one has a relif valve < all drum trucks and the other does not < disc. brakes >
Kathy
Now Cooper will try his best
You did.6166 Junkyard Dog wrote:I am missing something here cause you cannot mix up valves from trucks without disc and ones with disc. trucks without disc has to have pressure on all 4 wheels and trucks with disc brakes has pressure on the rear wheels only now also if the trucks 67-72 with disc. has 2 valves one under the cab and one under the engine saddle,, right now cannot say on 73-79 F-250's since not at the shop and sometimes research on web can be wrong,,, all 73/79 F-100/150's only have one valve so what I am missing and of course you cannot mix up master cylinders since one has a relif valve < all drum trucks and the other does not < disc. brakes >
Adding to my first post the early disc trucks used a seperate in line proportion valve on the rear after the distribution block. That is the piece that kind of looks like an inline fuel filter.
Here is a fordification topic with pictures covering disc and drum systems:
http://www.fordification.com/forum/view ... hp?t=53433
