reaming out bolt holes in a wheel.
willy3486
Post by willy3486 »
I have a problem I was wondering about. I have a Scotty camper and I would like to have a spare tire for. I bought a ford "doughnut" tire but it won't fit. I measured it and it looked like it would. But when I tried to fit it on the spindle the tire was a little smaller. I could ream it out a little and get it to work but I was wondering about the safety of it. If I drove no more than 30 mph no farther than about 10-15 miles do you think it would work? I only need to ream maybe 1/16 of a inch outward at each hole. Any suggestions?
depends upon a couple things i think.
1 is the shape of the hole. oblonging the hole may make it so the lug nut does not properly fit.
2. enlarging the diameter of the hole will make it likely to shift or move on the lugs.
if all you are looking for is an emergency spare tire it may work but if it does loosen it will mess up your campers lugs and possibly the spindle too. hate to see or hear of any accidents from this. myself i would keep looking for the correct one.
can you post the measurement of the correct pattern and maybe we can determine a wheel that would be usable?
willy3486
Post by willy3486 »
I am not sure of the measurements of the wheel I got. But I was told it was a ford. The hubcaps I bought today fit perfect. they look like the ones on the newer ,late 90s Ford Crown Victoria cars. I don't know what the measurements are on the hubcap. Anyway I was told on the camping site it was a 15" Trailer Wheel, White Spoke 5 on 4-1/2, 5" Width . There is a link on the camper site thats at http://www.etrailer.com/mm5/merchant.mv ... _Code=TPTW
I could buy this wheel, get it shipped and then get a tire but I prefer to just go to a junkyard and get a doughnut spare type. On a side note
I got a couple of the crank up jacks that fit perfect on the camper. I got 2 jacks,5 bucks each,2 hubcaps 5 bucks each ,and the tire for 10. Even though I can't use the tire it was still a good day at the junkyard.
