Looking for Distributor for 64 F100
hombre292
Post by hombre292 »
All,
I am looking to replace my original distributor on my 1964 F100, 292 engine, 3 speed. I want to go to a distributor that is breakerless, no points.
Does anyone know what my options are for this size engine? Do you know a vendor who sells the breakerless distributor? Thanks for your help.
Hombre
Hombre
1964 F100, Custom Cab
cdherman
Post by cdherman »
You could convert your existing one to breakerless points with a Pertronix unit. They work quite well. Only problem is that if they die, it is not exactly easy to get a new one at the corner parts place.
If you a little flexible, a cool solution that uses readily available parts is here at:
www.gofastforless.com
Doubtless, the Y block fans will soon chime in, but I'd think that even if there is an aftermarket solution, it will not come cheap......
1683
Planned/considered upgrades:
oldtrucks
Post by oldtrucks »
I have read some where that the dura spark guts will install in the dizzy and hook it up to the box and go.
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1962 UNI Short Box, Stock Y block, 4 speed Image
1972 F 250 4X4 429 4 speed Dana 70 rear
1977 F 350 Camper Special, Ranger, Super Cab
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
