SUV...Slick Utility Vehicle (Was: Crewburban Panel)
MeanMan66
Post by MeanMan66 »
eewww.....I don't think the rear door would work right with the forward lean of the hinge edge. You could suicide them?
not a crew but I like this better
finis origine pendet
36truck
Post by 36truck »
I could go for the Bronco Slick that's cool.
Tom Williams
bluebolt
Down under ambulances
Post by bluebolt »
randyr
Post by randyr »
MeanMan66 wrote:Image
You're right....making that rear door on the 4 door work properly would be a challenge. I think the basics of it looks better though. I'd still add another 8-10 inches behind the rear wheel.
bluebolt
Doors
Post by bluebolt »
Check out the doors on this crewcab for some ideas.
http://fordtruk.com/forums/viewtopic.ph ... ake+pocket
in2hotrods
Post by in2hotrods »
The 2 door bronco version looks like a 60's bronco concept ready for production. The changes required for the shortened rear doors on the 4 door would keep me from ever trying it. Definitely looks the part of most modern day SUV proportions though.
Bluebolt: Those rear doors look huge! I bet the rear passengers get in an out easier than the driver! Also, you got a pm from me.
1963 Fairlane Four-Door (Cruiser)
1966 Crew Cab (Project) View My Build Thread
Post by Gritsngumbo »
randyr wrote:
Gritsngumbo wrote:
That's the way the crew cabs were built. Guess if you're going to modify and build a back cover, you may as well go all the way and redesign the doors.
Yeah, Grits, I know that's the way they were built but to me they look like Ford was only thinking utility when they put that together without any regard for design or style. Looks like they just tacked on an extra cab and left it at that. If you compare with the crewcabs of today you can see they designed them to be a 4 door truck so the front and rear doors blend together like they were meant to be there. So, it seems like if he's going to go to the trouble to make a Slick SUV then it would be cool to really put some thought into all aspects of the design & proportion, including the doors. JMHO. Otherwise, he could just weld a snugtop on it and call it a day! LOL!
I thought that's what I said: "Guess if you're going to modify and build a back cover, you may as well go all the way and redesign the doors."
randyr
Post by randyr »
Yep, you did! I just took the long way for saying, "I agree." LOL!
I wouldn't mess with your original concept too much. I see what randy is saying comparing it to a modern SUV but you have to think 1966. IMHO, the cool way to do this is so period correct that everyone who sees it asks where you found it not how long it took to build if you get my meaning. Remaining close to your original proportions will pull that off better plus, it has a ton of character!
in2hotrods
Thanks for the encouragement Greg! I went out and started measuring today...now where did I put my thinking cap? :)
matt2491
Post by matt2491 »
The crazy frame-draggin' side of me thinks:
Just driving my truck.
in2hotrods
Thanks for that 3/4 rear view...I needed that!
I think I could shorten it up just a little behind the rear wheels.
Shiny
Post by Shiny »
You all know you gots me thinkin now eh! I could take my supercab cab and one of my crewcab cabs and mate em! I could cut the supercab at the door opening and then cut the back of the crewcab off and mate em up, only hard work would be to make the wheel opening.
What ya all think?
-Shiny
every movie I've seen the bad guy in the Camaro outruns the cop in the Crown Vic everytime!
'66 Merc "Crewlcab", SWB, clipped, c-notched etc
'65 Merc extra-cab,soon to be 3/4ton 4x4 SWBSOLD
'66 Merc J-Lo and Redford movie truck, from the movie "an unfinished life"
'66 Merc Crew Cab project 4x4 Cummins!
'65 Chevy crew cab
1961 slickwilly
Post by 1961 slickwilly »
i like the first concept no windows in the back keep it short slam it on the ground and black primer and red wheels with white walls would look great
