Mine and Matthew's (2) 1965 Ford Pickup builds!
ken462
Re: Mine and Matthew's (2) 1965 Ford Pickup builds!
Post by ken462 »
Great how-to article here from Hotrod Mag. on replacing floor pans. I replaced mine with no prior know-how or skill, just simply using the internet for info and how-to's when I'd get stuck. Didn't turn out perfect but no one will ever know, except me...and I ain't talkin :lol:
Happy welding...
EDIT: here's the link to hotrod article: http://www.hotrod.com/techarticles/gene ... ewall.html
Ken
Harper
Post by Harper »
thanks totten, and ken462
that article helps. I guess my biggest question was do I try and drill out the spot welds before installing the new pan...answer is definely YES...
I put a set of pans in a 70 bronco once and it turned out pretty good. I drilled every hole and welded thru them...I just was trying to get around the hard route...but I have since figured out, there is only one way, the hard way lol
thanks
Harper
Post by Harper »
today I unloaded a new air compressor, its been far to long between post here and its time to get started back on my old slick...
stay tuned...pictures to follow :)
Welcome back, Ben!
Harper
Post by Harper »
thanks toyz
seems everything I had my sand blaster guy do, was in vain, I need a shed for this truck, and will have to strip it down to bare metal again to be happy with it...pissin me off....
I have a couple questions though....which set of holes do my engine mounts mount in? I have them at least ready to install if I know which set of holes to use....
Can't remember for the life of me! In my case it is always the set I chose not to use. I'll check on my neighbor's 302 if no one answers. Don't feel too bad about the stripping, mine set in the shop and I have one which will have to be stripped and re-primed, and several others with marked deterioration since I absconded from the Midwest with them.
Harper
Post by Harper »
Yea its pretty sad that our beloved trucks have to sit while we find time and money to restore them... :(
that's what I tax money should go to until we retire lol
Harper
Post by Harper »
bought my son a "Igniter" points replacement yesterday, hope this thing works with years of trouble free service.
I plan on pulling his tank and cleaning it, there is either one of two things hindering his truck running good, fuel tank rust, or points were screwed up. I should know by the weekend. wish me luck.
I need this thing running soon, as I may be putting a paint job on it for my sons Christmas present from me :) (either a chepo spray glow paint for now with body work fixed, or I will attempt to paint it myself) I don't mind painting it, however I am no body man, so thinking the first time I will get a spray glow paint job, then I can move on to the mechanics for now, then later on down the road he can either let me paint it and help me or take it somewhere good.
Uncle Skip
Post by Uncle Skip »
Harper.
If you have the body work done the way you want (prep is what makes a good paint job) go down to your local Earl Scheib paint store, buy the cheapest option they have, take your own paint and tell the manager there's an extra C-note in cash in it for him if it turns out the way you want it.
http://www.earlscheibautopainting.com/
All those guys can lay down paint, its the prep work that makes or breaks a paint job.
The extra hunnie will make sure its done right.
Cheapest way I know of to get a good paint job without doing it yourself. 8)
Harper
Post by Harper »
uncle skip. I am with ya. I was just out in pearland tx a few months back (august) doing some training at magtech :)
Wish we had known; we could have arranged a tour of "Slick Country"! (No, Pat, not NE Kansas!).
Lots of projects "progressing" around the area.
And we promise to be, ahem!, a little easier to find when you get here :P
Harper
Post by Harper »
drivers floor pan in, passenger side cut out soon to be installed (hopefully this weekend)
JRANGER
Post by JRANGER »
nice work!!
Harper
Post by Harper »
thanks
wanting to go out there right now and finish the job, but I will go back to bed and start it a few hours later :)
JRANGER
Post by JRANGER »
yeah i know the feeling. Ive only been able to get a little bit in at a time lately
Harper
Post by Harper »
sanded and primed my core support today, my access doors for the front cab mounts, and one of my rear cab mounts...still looking for the other one :(
floor pans are in, both sides, and under the cab is undercoated with some spray can from rust olem.... still trying to decide what all else needs minor welding repair...
about ready to say Screw it and just put this thing together.
I am so ready to ride in this thing....
question:
if there is minor flash rust under epoxy primer will it keep it from rusting further?
I mean if its not getting oxygen, then is again primed and sanded then painted will it keep the flash rust at bay?
I need to know because if I am going to have to restrip this whole thing I am gonna just flat out be pissed.
Just my opinion based on industrial epoxy primers, but flash rust tends to weaken the bond to the metal. I'd be afraid of future peeling.
Harper
Post by Harper »
ok fellas a little help. Which Engine Stand (frame to motor mount) is taller Drivers side or Passengers side? ok never mind the tallest is the drivers side(found it on fordtification)
also if someone could which ones fit:
  • 302
evidently the 302/351 Windsor are 1" shorter than the Inline 6/ 390 FE Stands
  • 429-460
  • 390
  • 6 cylinder
I have (3) sets of frame stands for 390 (also same as Inline 6) 4 sale or trade
Harper
Post by Harper »
at least i did something Positive to my old slick today!!
my plans are a little at a time...and consistently. Hopefully I can get motivated. My 73 project truck and 90 other projects are taking up all my time...
sadly this is probably short lived, it will probably be removed before to long and 429/460 stands will replace it. I have a set ordered and on the way :)
