What have you done to your slick today??
azjake
Re: What have you done to your slick today??
Post by azjake »
Ice,
Years ago I had a 1977 GMC 3/4 ton with a limited slip rear end, which acted like what you say posi traction does. It had clutches that would get sticky and chatter is you did not change the oil as recommended or use an oil additive for it. That truck would get you in trouble on a snow covered road with a crown to it if you took off to quickly from a stop. Like, swinging the rear end around and put you into a ditch!
Most of my driving will be on pavement, so I need to do something with this rear end.
Jake
MadMaxetc
Post by MadMaxetc »
Did 3hrs of work on the PS headers!
My Build Thread
Harper
Post by Harper »
very nice!
totten
Post by totten »
This year i replaced brakes,radiator rebuilt with hoses and stat, new battery. General manti to my 66 Tony
CraigM
Post by CraigM »
Not so much today, but did some work this week.
Got a piece of wood and stain for the bed:
Wired up and installed guages. Finally have a working fuel and temp gauge:
Added some fresh paint to the rims and got some poor man's spider caps. Not for everyone but I like 'em:
Harper
Post by Harper »
Sent her out to the media blaster! :):):) updateed pictures by tomorrow nite!
a sneak preview of my cab, chassis after some of the blasting today.
It may not be perfect, but its a hell of a lot better than when i started :)
should have it completed soon and in epoxy! :)
HiBoy63
Ireland
Post by HiBoy63 »
Not so much what I did to it but what I did with it. Hauled all the summer skins from my other vehicals and various other items to storage for the winter with my 65 4wd.
65l5 by HiBoy63-65, on Flickr
65l4 by HiBoy63-65, on Flickr
65 loaded1 by HiBoy63-65, on Flickr
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
Harper
Post by Harper »
Removed the key cylinders, mechanices of door handle abd delivered both doors to the media blaster. Cabin in epoxy, as well as frame.
Mrsinister
Post by Mrsinister »
Cleaned up the surface rust in the interior and got a fresh coat of por on it
F7BIGJOB
Post by F7BIGJOB »
Added about 30 gallons of gas to the F950, took it on a decent 20 mile shakedown, runs good, I'll run it a couple of more times, toss my paycheck into the fuel tank, and hopefully sell her.
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
longcabjohn
Post by longcabjohn »
Finished removing the bed floor and test fit the 87 floor, a little fine tuning and it will be time to start welding.
Johnny
Post by Gritsngumbo »
Started Little Red, changed the rear tires, will get her out and give her a wash this afternoon and take her down the road to a "Show and Shine" at the local McDonald's.
Shadow
Post by Shadow »
I Feel Like A Mere Piker With My Modest Achievement. I Changed The Oil And Completed The Break-In Period On My Rebuilt Y-Block. The Truck Runs Like A Top And Even Turned A Few Heads Today. The Project Is Really Coming Together And I Couldn't Be Happier...............
MadMaxetc
Post by MadMaxetc »
Picked up my re-drilled Axles and Drums!
Image Image
My Build Thread
Harper
Post by Harper »
deliverd the paint and hardner for my chassis, and bottem of my cab. Lined up my Flareside bed being blasted.
BigMike
Post by BigMike »
Put it for sale :shock:
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
64shortbed
Post by 64shortbed »
Installed a mechanical oil pressure gauge on the column (Stewart Warner Greenline)
-don
'64 F100 262-I6
White97
Post by White97 »
I finaly got my new 3-core aluminum radiator installed. Two trips to the custom shop to have some aluminum welding done to have this direct fit rad from radiators4less fit. :cussing: Looks good and really helped to clean up the engine bay, old rad looked like it had been installed with baseball bats and hammers.
I dropped off the 4spd Top Loader from the 68 galaxy for a rebuild/refresh when I picked up the radiator. Can't wait to stir from the floor. Off to Summit to order the Hurst shifter and assorted pieces today.
Lou
1965 F100 Short Bed
Harper
Post by Harper »
Ordered my cab mount kit, floor pans, and a few other small rubber items. :)
Brians1966
Post by Brians1966 »
change oil and filter, lubed front end, u joints and slip joint, washed the old girl, then went for a ride
1966 F-100 LONG BED, 240cid 3 speed red and white, Red and White Interior with a Mossy Oak Seat Cover
2013 Ford F150 STX Supercab 5.0 litre
DETERMINATION: The feeling you get right before you try to do something incredibly stupid!
CONFIDENCE: Is the feeling you have before you fully understand the situation!
