Trip 106, Fall 2015, Kuwait
001/004 Pilot hero shots.
005 Loadmaster hero shot.
261 Another fill ‘er up Friday. By the book and everything to show another brand new dollar rider copilot the way it is done.
262 Normally I don’t photograph the cargo for security purposes, but this tactical movement of tactical pallets of pallets…
263 Vol III separation of thunderstorm avoidance procedures followed as this beast was no joke.
264 Fastest I’ve watched a stateside storm build ever.
265 Even as tough as our engines are, going in there would for sure exceed the water ingestion rate, and we’d all be dead shortly thereafter.
266 I couldn’t get the gopro out fast enough for how quick that little guy was building.
267 Next day over the Cradle of Civilization. Water is life for sure.
268 Can start to smell the desert air comin’ in.
269 Big Airbus beast of a unit that makes a C5 look small.
270 First trip wearing the 1500 hour mark.
271 “Oh shit,” I said to our dollar rider copilot on this trip. “Our pilot’s side Heads Up Display has flaked out. Looks like the NovRAM has gone all corrupted.”
Aircraft commander says, “Hmmm, since we need this for the next leg of the mission being a night vision goggle assault landing, gonna have to fix this one here before we take off.”
“Can you do that chief?” the dollar rider asked.
“Well, the book calls for some special equipment after I cold-start the HUD after dumping the NovRAM for the boresite alignment, but I’ve done this enough in my pre flying days as an avionics tech to wing it. You’ll be right on target, but I’ll need your help.”
As the AC nods in agreement, the dollar rider looks around and says, “That sounds made up.”
“No, here look. Put the maintenance monitor panel power on, select avionics ground bit to on, press and hold the copilots MFC panel test button in, observe the test digits displayed in the copilots HUD, and compare that to the DIP switch data plate under the copilots CNC panel. If they match it’s good. That’s what I’ll have to set up on the pilot’s side HUD while I’ll have you stand out front to compare the return against.”
“How’s this chief?”
272 “Lookin’ good Lt, just a bit to the right.”
273 “Now put your right foot in, and take your right foot out. Do the hokie pokie, and you shake it all about…”
274 But really yer the most on point focused new copilot I’ve ever flown with. Good job on a successful dollar ride.
275 No more dickin’ around as the sun sets on another desert night. We gotta go! ‘Till next time on the next trip.
