Page 8 of 13
Posted: March 4, 2011, 7:17 pm
noley99 wrote:Looks good Greg, your pics are clearer when there is no Lager involved :lol:
You are right Ashley - no lager.
I was sipping Shiner Bock.
I'm not sure why some of the other pics were a tad fuzzy. Sometimes the light in the garage plays with the camera's auto focus I think.
Actually Alan the biggest problem with the core supports is that the 1/4 drain hole clogs too easy. You either have to clean out that U shaped channel at the bottom, or drill the hole bigger. Other than that they are fairly well designed for weight vs strength.
Posted: March 17, 2011, 8:32 pm
To lick my wounds from the 62 leaving I decided to work on the 64 some more.
Since I have the rear patch all made up (needs some trimming). I decided to work on the other patch.
It's made from 16ga which is thicker than the support - I wanted something substantial to weld from because the stock metal will be even thinner after blasting.
Bad spot cut out;
Patch fit;
If weather allows I'll blast the support this weekend.
Posted: March 18, 2011, 8:04 pm
Finished my bearing install on the 5.0. This is ALOT easier with some natural light, lol.
The short block is from an Explorer, they have an idiot light that tells you if it's 1 qt low on oil - 64 F series do not have this light, lol. I need to remove the receptical for it and put a threaded plug in there, I discovered after the engine was in that it's not sealed without the sensor. I'll do this tomorrow and get the pan back on. Then I can put a block & bottle jack under the pan and pull the tranny again. Still need to install the clutch, presssure plate, release bearing, and pilot bearing. The tranny was only installed to measure the floor cut out for the shifter and hold the engine up for a while.
Posted: March 23, 2011, 7:52 pm
Weather took a turn for the worse here so I decided some small projects were in order.
I still needed to repair the rust spot in the passenger side inner fender. I drilled out the 6 spot welds, threw the brace in Blue Lightning and cut out the rusted spots - I ended up with 2 after getting it apart. I got one patch fit and welded in last night - did the other tonight. I still need to grind down the welds and get some weld through primer before I weld the brace back in.
Sorry no pics - camera battery is on the charger.
I'll get some though.
Posted: March 23, 2011, 8:52 pm
by MadMaxetc
Glad you are makeing progress Greg.
How are you liing the extra room? :)
Posted: March 23, 2011, 8:59 pm
MadMaxetc wrote:How are you liing the extra room? :)
Rear end of the Scort isn't hanging over the sidewalk anymore, lol.
Next weekend the Jeep will probably go in that space. I need to mod the track bar mount on it - need to extend it 2" to recenter the front axle because of the lift. Also need to swap out the drivers door shell and fix the drivers front fender - it WILL be finished this summer.
BTW, that baseboard cleaner aerosol makes a really good cleaner/degreaser!
Posted: March 25, 2011, 9:28 pm
I promised pics after the camera battery recharged.
I got one of the patches cleaned up a little - will finish the other this weekend.I am redrilling the spot weld holes for rosette welds too.
Inner fender brace.
Soaked in Blue Lightning to get it cleaned up abit - still need to clean the seam sealer off of it. I'll shape the rust hole in a little and run a weld bead around it = sort of a big rosette weld, lol. This will be less of a PITA than putting that small of a patch in and will still keep moisture out. This is on the under side of the inner fender and will be coated with bedliner any way.
Posted: March 27, 2011, 4:50 pm
All fixed,
just need a coat of weld through primer and it's ready to burn back in.
After it's welded the edges will be filled with some seam sealer - keep the moisture from getting back in and rusting it again.
Primer the rest and then paint!
I am half tempted to drill the brace out of the other one and clean it up too.
Posted: March 28, 2011, 12:34 am
by HiBoy63
great work my inner fender has rust right in that very spot. Must be a weak spot a trap for dirt and water.
Posted: March 28, 2011, 10:44 pm
HiBoy63 wrote:Must be a weak spot a trap for dirt and water.
Most of them I have seen looked just like this one did - or worse. Curb side, they salt around here, traps salt water = hole, lol.
There was some seam sealer in there - not alot though. They would have had to try and pack it in after it was assembled though.
Posted: March 31, 2011, 8:02 pm
Brace welded back in tonight. Started cleaning it up.
I put some Devcon Metal Filler as a smoothing coat on the side that was ground - I'll sand it smooth tomorrow after it's good & hard.
It will take me less time to get the whole front clip on than it fixing this one inner fender - LOL.
Posted: April 1, 2011, 9:41 pm
All ground down - a little Devon filler over it.
I'll let it dry overnight and sand it out tomorrow.
If all goes well (may rain) I will get the bedliner on the underside this weekend.
If I can't spray it I'll get back under the truck and button up the clutch & T-5. My pressure plate came in today. Trans insulator showed up too - now I can build the crossmember.
I was having an issue with the starter,
the one I have doesn't have a solenoid (which is what I want) but had the wrong number of teeth for the flywheel. I bought a rebuild kit for 77 - 91 starters mostly for the drive. I haven't rebuild a starter since high school - this should be fun.
Posted: April 4, 2011, 7:19 pm
The inner fender is ready for paint.
Coat a primer on the repaired area after a little sanding. This is by no means a show truck repair but will look OK hidden under the hood hinge & battery tray, lol.
Rustoleum aerosol bedliner on the underside of it.
It sprays kind of odd, goes on pretty thin compared to regular bedliner. Since I want as more of a chip resistant paint it should work very well - I wouldn't want it too thick under here anyway.
Posted: April 6, 2011, 7:51 pm
Bedliner on the drivers side inner fender (yes it's still wet).
Coat of high heat paint on the spacer.
The tranny, clutch, PP, etc. will all go back in here in the next day or so. Then the crossmember can be built.
Posted: April 6, 2011, 9:10 pm
by Power by Ford
Greg
Both the core and inner fender repair look good. Does the spray liner dry hard or does it stay pliable?
Posted: April 7, 2011, 12:23 am
by HiBoy63
The inner fender looks good. I might have to go that route with mine. What color is the motor compartment side. Gloss semi or flat??
Posted: April 7, 2011, 2:30 am
by Alan Mclennan
Greg D wrote:Image
Greg!, that's not your thumb is it! :P
Posted: April 7, 2011, 5:44 pm
I haven't decided whether the inside will be gloss or semi gloss. The only thing painted at this point is the firewall (Rustoleum Rattle bomb gloss black) and since nothing has been put back on it adjustments can be made. Firewall is no where near as shiny as the frame is.
Yes Alan that is my left thumb.
:dontknow:
Before you decide to get ornery remember - we have pictures of your feet and we're not afraid to use them. :shock:
Posted: April 10, 2011, 8:05 pm
Been painting some small pieces is about all.
Oh one other thing got done this weekend,
the transmission is in and this time with the clutch, PP, etc.
Now I can figure out the clutch cable, build the crossmember and measure for the driveshaft to be shortened.
Posted: April 22, 2011, 9:03 pm
I was going to do it myself but due to a lack of time I had the core support sandblasted.
I picked it up today and decided after a little work on CLBC (broken spring) I decided to work on the support (much more fun anyway).
I shot a little etching primer on some of it so I could handle it first.
Then I decided to burn part of the patch in - I have to drill the drain hole before I install the front patch.
No I won't clean up the weld on the inside since it will be covered.
I knew I would find this after it was blasted;
This I did not expect;
I guess I know how I will fix it though and I'll have had practice, lol.
BTW - this stuff is GREAT! It's a bit pricey but it's GREAT!
