azratrods '64
Reds Rod Shop
Post by Reds Rod Shop »
I agree, I like the 2 creases in the roof also. Sweet built, Can't wait for the pics of the work that you mentioned above. Red
SixtySix Ford
Post by SixtySix Ford »
Sweet build Dave! I really enjoy watching your work! :D
"Nitrous is like hot girl with STD's. You know you wanna hit it, but your afraid of the consequences."
66 Ford F-100 - Project SickUp
azratrod
not dave
Post by azratrod »
im aerik not dave. im assuming your thinking dave "garbz". dave is part of team "chelsea" though. hes been my mentor and the driving force that keeps me spending money and doing alot of the work on this truck
'64 ford bbw custom cab short styleside bed
'32 ford 5 window body
'28 ford roadster pickup
'04 ford f150 crew cab short bed
azratrod
a new computer helps with uploading pictures
Post by azratrod »
cleaning up the cut
cutting pieces to put in the area where the cross member was notched
cutting some material for the crossmember notch for the driveshaft
the back side of the front crossmember
the emergency brake bracket welded back on
the front valance back on
cut and lengthened the radiator support. it had to "grow" 2 inches because the front frame horns were notched
slickmainer
Post by slickmainer »
looks good, it's snowing here :cry:
--Gregg--
you can't get there from here
Bill W
Post by Bill W »
it looks even better in person AND man is it LOW!
azratrod
new computer, new pictures
Post by azratrod »
thanks bill. did you talk to garbz about the headers, steering box, and dash piece?
passenger side of the frame notched and the lower part of the radiator support notched
drivers side notches
9" off the rough ground to the bottem of the frame! at the drivers door area
the lowering blocks in the rear are bolted in
profile view of the chassis
drivers side frame horn notch
drivers side notch almost finished
Bill W
Post by Bill W »
Yeah, i was up there over the weekend. we got the front clip pulled off of the black truck
MadMaxetc
Post by MadMaxetc »
Looks like she is coming right along!
Tell Garbz I said Hi! (Does he still want to do my Dakota rack mod?)
My Build Thread
azratrod
Post by azratrod »
sounds good jim.
madmax, ill tell him you said "hey". i dont know about what his work load is after we finish my ride. i know hes starting to play with "christine" here and there.
we have lakes pipes! big long 70 inchers
MadMaxetc
Post by MadMaxetc »
Ooooooh...shiny!
My Build Thread
azratrod
work done over xmas break
Post by azratrod »
my old ranger seat brackets that i had in the '64. they were the wrong brackets. they are for the '67 and up trucks. i traded them to bill w. for his ranger repops that he is selling. these '67 and up truck brackets worked ok in my truck, but the new ones from bill will be perfect. there for slick rangers
here are the slick ranger repop brackets bill w. is selling. these are the ones that will be going into my truck. bill w. will be taking my old brackets and repoping them also. contact him for more info
removing the center section of the dash
the new center in place
the center piece in place with the trim
a perfect fit on the drivers side
starting to reinforce the rear section of the window
finished up
the bbw section fit back in
olliesshop
Post by olliesshop »
Beautiful metalwork !!! I can't wait to be able to get restarted on mine.
Tim - 1961 F250 Uni
azratrod
as of 1.16.11
Post by azratrod »
bracket finished
trimming a little
finishing up the dash piece bracket
drilling holes in the bracket
bracket mounted
the mad scientist at work
the floor filled
the steering box mounted. thanks bill w. had to slice the shock towers to lean them in a bit for some clearance
the bracket
notched the frame to fit the steering box in
azratrod
steering coulumn raised and mounted
Post by azratrod »
eveything is still a little rough but its in. the coulmn has been raised at the fire wall and at the dash. its also been centered too. no more having to lean to one side
kstones63
Post by kstones63 »
Aeric,
Let me know when you are coming up to work on your truck. I want to stop by and see the progress and garbz.
Every project has to have a little bit of blood to make it complete. I see blood running down your leg.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
Looks real good guys!
I can only see one problem;
It's 1* here as I type this - high of 12* today and you are wearing shorts!
Bill W
Post by Bill W »
80 + degrees around these parts Greg.
when is the next build day Eric?
Bill W wrote:80 + degrees around these parts Greg.
My scoot wouldn't be a garage decoration under a cover if that were the temps here...............
azratrod
blood
Post by azratrod »
kevin, i was cutting a section of frame off an old frame. it came loose and cut about a 6 inch gash on my shin. then it caught me on the ancle bone.
bill w., garbz will be working on the truck saturday and sunday. i have to work saturday but ill be there all day sunday.
the weather is almost a little hot for it to be "winter time". but im not complaining. i think ive had pants on maybe 6 times in the recent few months.
