Greg D's Traditional Build of a 1964 F 250
Casey 65 wrote:Greg, send me a color sample of the Ford Bright Calypso Green Metallic (tape or paper from masking would be fine when you paint)
I can do that Gerry - be likely quicker for you to just look at an "aqua" 92-93 Mustang or 92-94 F 150 like the one I posted though.
Coating the stone guard support bracket with bedliner.
It was bent & rusty so I straightened it and took it to bare metal - didn't bother filling the pitting in it though.
You can see some painted in fasteners in the backround too.
It's raining today - going to hold some things up a little (I was going to put everything but the truck outside so I can get it up on stands).
After the coating locks up I'll spray the bottom side and then make the seals for the inner fenders and rivet them on. Because I bounce around from piece to piece a little I always seem to have a rainy day project laying around.
"Reminding" my new inner fender seal material what shape it's supposed to be.
Rear seal on the passenger side cut and riveted in place;
"Bumps" stuck down with some weatherstrip adhesive;
1 down - 1 to go.
1 down - 1 to go.
Drivers side done;
Not anything massive done today.
If I keep this up I may actually turn this garage full of parts back into a truck one of these days though.
Today I put it up on jackstands (again, lol).
This was yesterdays plan but rain held things up (I had to move stuff outside for some room).
I got one of the plates Matt made welded in. I figure if I have 1 in place I can match the other side to it.
This crossmember needs to be connected - it doesn't just hold the Y & 6 engine mounts - it ties the rear spring mounts together.
There are 4 of these plates, 2 will be welded in place - the other 2 will be bolted to them. Tubing will connect the 2 bolted in plates - that way I can drop the center of it for maintenance, etc.
I didn't do a whole lot tonight.
I adjusted the steering stops - drivers side tire was kissing the pitman arm grease zerk and wasn't even close to hitting the stops. Calipers were also touch the axle at full lock.
I hung the passenger side inner fender - partially just to get it off of a table.
I won't install the drivers side until I get the plate welded to the crossmember stub - that way I won't have to reach over it to weld.
I did find this pretty nice to do with the truck up on the stands - was a much better height than on the ground where I'd have to darn near be on my knees to do it.
Gregg, its been a long time since I visited your build. You are really making good progress, I especially like your fender seals.
Michelle
Thanks Michelle.Michelle wrote: I especially like your fender seals.
Just trying to stay at it.
Right now they aren't even touching the firewall - core support is all the way forward in the slots though too. Have to see how they fit after I hang the fenders and get the front clip adjusted.
Hope to have the rest of the under hood & under truck stuff done in the next couple weeks. Then I can shoot the fenders & upper valance and hang them.
As soon as it's on the road I will stop working on it for awhile - need to finish the Jeep.
After much consideration I have decided to go with a hydraulic clutch.
Setting it up for the cable is either a serious PITA or expensive or both and then I will still have routing issues for the cable around the headers.
The clutch pedal is the same for either setup in stock configuration - main difference is they weld an arm on the pedal for the rod. This rod partially covers the hole that the pushrod bolt goes through - it had to go.
A cutting wheel, grinder with flap wheel, 2 lb sledge, a beer, and an air chisel solved the problem quote well (The way this was welded they made SURE it wasn't going anywhere!)
I also cleaned up the brake pedal since I have them both out. I will coat them with more of the Rustoleum Aerosol Bedliner and put on the new pads I have.
I decided that the bedliner was "The Stuff" to coat the pedals with.
I'll flip them over and spray the other side tomorrow after this sets up good.
Other side of the pedals painted;
New pads & ready to reinstall;
And now for a little "temporary" reassembly.
Next will be build the tranny crossmember - I picked up the metal yesterday;
Been a while since I posted here.
I haven't actually "technically" worked on the truck but I am getting things arranged so I can get back at it.
I got everything but the 292 unloaded from the truck today. I have decided to store parts in the basement - I can also work on them down there where it's cool and they won't be taking space in the garage.
I get things arranged down there and I'll pull most of the front clip back off then it's back to the hydraulic clutch system, then the crossmember.
fire truck
64shortbed
Here are some pics in her new home - some of them are almost 2 months old now though...............
Finally got my cabinets and compressor in place over the last few weeks - still a mess though. I still haven't found everything either, LOL. I got the compressor wired a couple weeks ago.
Now back to business, (after a nice ride) I went to work "re: dissembling my truck. As shown in a previous post it was bolted together to bring it home here. Now I can get back to the hydraulic clutch setup - after I find the slave cylinder that is...............
fire truck
