ok so i'm a little late, but,I actually have a 292 in my 61 and would love to have some of your knowledge. i have the three speed three on the tree and would rather have a better range tranny.
my son has the t98 in his 61 223, and it is a little low geared (struggles past about 60mph but will hit 70 on a good day).
so what do you suggest for the geared illiterate???
Borg Warner T19 for my slick.
tranny swap
Well since my saginaw power steering swap requires column work I have decided to go ahead and get the transmission swap done at the same time. I wanted to compare the gas mileage with the old 3 speed but never got a chance to really drive the truck due to the bad brakes. Since I won't be changing the rear gear ratio for a while I can still compare the mileage after I swap to the 3.31 Dana axle from the 3.70 gear axle I have now. here's a little comparism between the 3.03 3 speed/3.70 gears I have now and the T19/3.31 gears I will have in the future.
1st 2nd 3rd
3.03/3.70 2.99 1.75 1.00
x rear gear 11.06 6.48 3.70
1st 2nd 3rd 4th
T19/3.31 4.02 2.41 1.41 1.00
x rear gear 13.31 7.98 4.77 3.31
1st 2nd 3rd
1st 2nd 3rd 4th
Started swap
Well I started putting in the T19 in my 66 longbed today in place of the 3 speed. No issues so far, bolts right in. If you have a known good pressure plate and throwout bearing you would not even have to remove the bellhousing. Awaiting trans mount to finish installation.
Glad to hear the swap is going well. Driveshaft length the same as with the T-18?
factorystock
The "56-73" thing must be a typo, probably meant 66-73.Just like there are different engine family's there are different transmission family's. I know what I would do if it was 40 years ago, I would look at the transmissions Ford offered in F 500 and F 600's trucks that came with 223 and 292's. Ford offered the Clark 5 speed (250 V ) and Clark 5 speed overdrive(251 VO ). The transmissions would easily bolt into a 61 thru 64 pickup with the same engines. Finding these transmissions today in good shape, may be a challenge.Gritsngumbo wrote:Jason: The link you posted says the T18 was: "Used in Ford trucks 1956-73" which I would think should include Y-Blocks and the 223 "6", but only the T98 is mentioned in the 61 Ford Truck Shop Manual (and 62/63 Supplement).
Got to take the 292 w/T98 out of the parts truck to see if a T18 or T19 will bolt up (if I can get it done before Bluebolt installs his). Everything I read indicates that the cases of all three are "essentially" the same (whatever that means).
