88 crown vic frame swap for 61 unibody
61ford
Post by 61ford »
lord no lol itll end up getting some torque thrust or the polished aluminum wheels on the new mustangs
Ryan
351w/Aod
Robert
Post by Robert »
i would like to see the mounts when you make them [/u]
There are some real good deals on new Mustang tire & wheel sets on Ebay regularly.
http://cgi.ebay.com/ebaymotors/MUSTANG- ... 06.c0.m245
http://cgi.ebay.com/ebaymotors/05-06-07 ... 06.c0.m245
Just do a search 05 06 07 08 mustang wheels.
61ford
Post by 61ford »
started my thought process on the mounts going to change the ends of the factory mounts and weld them onto the factory crown vic mounts
tranny tunnel needs no mods for a aod anyway
Ryan
351w/Aod
twistedfreak
Post by twistedfreak »
nice work ryan kepp it up the torque box will go out as soon as it get boxed up and you send me the cabbage
""WE THE WILLING, LED BY THE UNKNOWING, ARE DOING THE IMPOSSIBLE FOR THE UNGRATEFUL""
JFCDeuce
Post by JFCDeuce »
Just be warned that 05+ mustang rims have a +45mm offset, on an '88 frame I think you will need to run wheel spacers, or use the older Torque thust styles from a pre- '05, they have a +24mm offset.
I believe that the '88 era vic wouldn't have had a wheel offset. What is the hub to hub measurement on the front and rear compared to the stock uni set up?
"Let the Devil have his Chevy, thank God Jesus loves His Fords." -Angry Johnny and the Killbillies 'Creepy Pete'
61ford
Post by 61ford »
idk what the hub measurements once i get it all mounted ill worry bout my offsets but i do know this from what i can tell so far the wheels stick too far inside the body i always like my wheels for one the front and rear track width to match and two for the outside lip of the tire to line up with the edge of the fender
Ryan
351w/Aod
61ford
Post by 61ford »
Ryan
351w/Aod
61ford
Post by 61ford »
just going to give an update fixing to get started back on the truck school has slowed me down.im not much of a metal fabricator and my body was pretty rusty so ive enlisted the help of a metal fabricator and were going to fix all my screwups on the body and finish getting my body mounted mounted on the crown vic frame after the holidays
Ryan
351w/Aod
61ford
Post by 61ford »
finally did get my rear mounts welded in.got my front figured out just aint carried out the plan yet
Ryan
351w/Aod
61ford
Post by 61ford »
heres the front mount
Ryan
351w/Aod
hungrymonkey
Post by hungrymonkey »
Any pictures of the rear suspension coming through the bed?
66 F100 SWB
67 mustang coupe
73 Mach 1
Drive it like grandma stole it.
Never poke another mans rust bubble.
White by birth, trash by choice.
61ford
Post by 61ford »
should have some somewhere check out my photobucket i think i have a link.idk how far it sticks out past the factory floor as mine was tossed a long time ago and im fixing to raise it to clear the suspension and put a wood floor in it
Ryan
351w/Aod
61 Merc
Post by 61 Merc »
Ryan, any chance you can get some pics of the inside box for us, I checked your photobucket account and you don't have any posted in it. I may be doing this to Jinx now since the dakota install will not be going on. Keep us posted of your progress.
Dean
61 Mercury SWB Uni - Project
63 Ford SWB Uni - Parts truck
61ford
Post by 61ford »
yea i can but theres nothing in it so far other than some wheeltubs from a 64-66 that i think ill prolly end up widening a little depending on my wheel offset i measured one time i think from the bottom of the brace that runs across the bed at the tail lights "rollpan" looking thing like 6 inches just to clear the suspension buckets ill come up with some
Ryan
351w/Aod
61ford
Post by 61ford »
just going to give an update i hadnt forgot those box pics progress has been a little slow having to change out my roof and im starting on that saturday then im going to fix where i notched the floor for the frame and start working my way toward the back of the truck
Ryan
351w/Aod
61ford
Post by 61ford »
finally started swapping roofs
Ryan
351w/Aod
61ford
Post by 61ford »
pic of it sitting there
64 roof sits alittle bit farther back
Ryan
351w/Aod
twistedfreak
looks good and if you get a chance get me those dim. for the door steps and ill get them started
Robert
Post by Robert »
Do you guys know if a two door ltd frame will work under a unibody
