sgart80's 64 f100 rebuild
sgart80
Post by sgart80 »
I've had the bottom of the cab pieced back together and sandblasted and primered for about two weeks. I just now got camera so I don't have to borrow one from work every time I want to take a picture. I still have a long way to go on the cab, the rear cab corners need to be built up. I have the cab floor patched and front cab mounts reworked. I am not very pleased with my results so far. My welds look bad and I’m having a hard time grinding them down so they look good. I've had some people suggest that I just get some bondo with fiberglass strands in it and go over them with that. Also, I can't seem to weld without burn through. If I don't weld on the fringe of burning through, then I don't get good penetration. Overlapping sheet metal looks awful and it will rust where it's overlapped but I can't hold the grinder steady enough to cut a piece of metal straight to butt weld it. I'll start with a large piece, then work my way down so it fits, but I always end up with a side that doesn’t butt up. I’m frustrated with it to say the least.
Here is a shot of the bottom:
[albumimg]6850[/albumimg]
Here is my patch job.
[albumimg]6851[/albumimg]
[albumimg]6853[/albumimg]
I guess it's come a long way from here.
[albumimg]6418[/albumimg]
I feel like I should chalk this one up as a loss and find a better cab. I’m kind of at the point of no return on this one, I’ve been working on it on and off for the last three months, I’ve probably got about 60 or 70 hours of labor into it, and that is just the bottom of the cab.
Here is the cab floor:
[albumimg]6854[/albumimg]
Which is also uneven and full of holes from burn through.
I guess I am learning a lot about metal working and fabrication and welding, and that was kind of the point. Any words of encouragement or suggestions are welcome. Feel free to laugh at my pigeon poop welds. I’ve done my fair share of head shaking over the whole ordeal.
Last week I started cutting into my radiator support in a ditch effort to save what’s left.
I’ll let the pictures speak for themselves:
[albumimg]6855[/albumimg]
[albumimg]6857[/albumimg]
Any suggestions on how to keep from burn through would be appreciated. I just assume it's because the old metal is so thin everywhere. I have read some of your suggestions about getting a piece of copper and holding it behind the metal. I guess I'll have to try that next.
yay, more burn through:
[albumimg]6859[/albumimg]
In summation I’m disappointed. Mostly because of my lack of patience and less than perfect results, but the project still has forward motion. I’ll update again when I have more to report.
End transmission.
ezernut9mm
Sweden
Post by ezernut9mm »
don't get discouraged. keep trying. i know what you're going through with the welding thing. i bought a used stick welder and went to town on mine doing the same thing you are. the cab was pretty well rusted through in the floors and cab mounts so i figured i couldn't do any more damage that what was already done.
i say step back, have a cold one (or whatever be your drink of choice) and start again after you have cleared your head.
this can almost be fun if you don't think of it as work. lol
Anthony
Post by Anthony »
I agree with Ezer.... I find an evening in the garage burning holes through the metal kinda relaxing... :lol:
[albumimg]5221[/albumimg] [albumimg]5222[/albumimg] [albumimg]5223[/albumimg] [albumimg]5909[/albumimg]
and check out my sig.... yes they are the same cab..... I have more in fixing the cab at $20-$30 a whack than I could have bought a good one for. but shipping is expensive and around here, if it is still here it is rust. :lol: :lol: Think of it as meditation (not to be confused with mediCation) and enjoy the experience....
Anthony
sgart80
Post by sgart80 »
Thanks for the positive reinforcement. :) I guess I do need to chill out and relax; afterall, it is a project. 8)
dotcentral
Post by dotcentral »
I have the same problems with welding, burning through or not getting patch pieces cut right, so I have a big gap to fill. I'm a complete novice, trying to learn.
For me, a thick copper sheet is good for putting behind the gaps, it lets me fill the larger gaps with weld. I spend a lot of time, but I guess I'm slowly learning.
I've been told if everything is adjusted right, the speed is correct, it should sound like bacon frying. I figure on some of the blowouts, it was weak/thin metal so I try not to stress, just fill it back in next time.
A hand grinder helps me for welding clean up. I use both a rigid grinding wheel and one of those flap-type wheels. I try to use the first one for rough work, the flap type for getting it a bit smoother.
sgart80
Post by sgart80 »
I finally ran through the spool of wire that came with the welder. So I bought some new wire, and popped open the cover and low and behold the gas line wasn’t hooked up. All this time I’ve been welding without gas. Having never welded before, it never occurred to me to check to see that that internal gas line was hooked up or that I should here the gas coming out of the nozzle when I pull the trigger. Long story short I’ve been able to pool some welds and correct some of my burn through problems. Bad news is, every old weld and all the “new” cab patches I’ve done need to be ground out and re-welded to make sure I have penetration. It was a relief to find out my mistake, although it would have been nice to find that out sooner. I guess that’s what I get for not insisting on help from someone with experience. I ordered an auto darkening helmet from northern tool, it should be here tomorrow. Hopefully it will be everything the reviews say it is.
http://www.youtube.com/watch?v=oUhD63fmB-k
I’ve been holding off doing any more welding until my helmet gets here, I did get some sandblasting done this weekend though.
Radiator support, or rather what’s left of it:
[albumimg]6956[/albumimg]
[albumimg]6957[/albumimg]
I got my pedal bracket blasted and primered.
[albumimg]6958[/albumimg]
I also did the inside of one of the fenders to see how it would turn out:
[albumimg]6959[/albumimg]
Nice work!, have you considered a new support?, that one looks like it`s past it!, IMO, watch the batteries in the auto helmet.
sgart80
Post by sgart80 »
I agree, it is also my opinion that fixing the support is more work than it’s worth. I've considered buying a new support and I've considered buying a donor truck. I've priced them I've scratched my head and I've debated, but I can't make up my mind. I have a hard time shelling out $300 plus shipping for a support when I only paid $400 for the truck. Then again, I got what you'd expect to get for $400, a rusted out, ran when parked pile of old tin. I guess I'm kicking myself for not taking more time and picking out a truck in better condition, but it's my first project, and hind sight is 20/20. This entire project has been one huge learning experience. I’m trying to bend my own patches and learn to work the sheet metal I need to focus on getting the cab in order and reworking the floor and cab supports and cab corners. I have all kinds of time, and being budget minded, I’ll probably try to hammer out some metal and weld it in place and hope it fits without too much coaxing. I’m really fighting ordering patch panels and re-popped parts.
The new welding helmet just came in, it’s solar powered, so I don’t have to worry about dead batteries. I’m going to dig into the cab tonight, cut out all the “new” patch work and start over. The second time around will be better, and hey if I do it one more time after this, they say, third times a charm.
You are doing a fine job.
I must say I like your "can do" attitude!, keep us posted, where are you, someone maybe nearby that has a good support.
sgart80
Post by sgart80 »
I didn't realize I never filled out my location. it's updated.
I'm always browsing the local craigslist and classifieds and look on ebay for trucks and other parts, I just don't really have the room for another whole truck to sit there in the drive while I pick parts off of it at my leisure.
I got to work last night cutting out all the bad parts again, I even went a little further than the first time because I found more rust. The cab really is in sad shape.
[albumimg]6988[/albumimg]
[albumimg]6989[/albumimg]
tschmitt
Post by tschmitt »
Hey your not too far from me, I live in Vandalia IL. A little southwest of you. Your making great progress by the way, looking good.
Anthony
Post by Anthony »
sgart80 wrote "The cab really is in sad shape."
Have you looked at what I have and what I started with.... If it is metal it is fixable and I have more time and 20 dollar bills than I have a good local source and 300 to 400 dollars for a whole cab. It seems as though I can get patch panels "right now" easier 'cause the money wouldn't last long enough to reach the goal of the price of a whole cab. (you also have to remember that I had 2 cabs and this was the better of the two.. :roll:)
I think that you are doing a better job than me and I thought mine was descent. your patches are turning out real good and primed they look awesome. What are you going to do to the bottom side? (Paint, powder coat, under coat, or what I did....Wal-Mart bed liner)
As far as time, you are making better progress than me. I have spent the last 2 1/2 years on mine with a good year and a half on the underside and the cab. I still have cab corners to do but will not have them done by slickstock :shock: , nor the front fenders. but it will be in a primer of sorts and ready for the road. I am shooting for reliability by slickstock.
Just keep pluggin' along and keep in touch with us and be sure to keep the pictures coming. Pictures are an inspiration for all of us, finished or not.
You are not alone in this journey, just remember that this is "FUN".
Anthony
jammck66
Post by jammck66 »
Hey, truck is looking good. really coming along.
If you want help with your patch jobs, use LMC truck as a resource for such items as cab corners. it takes an immense amount of skill and patience to bend steel. it really is easier to get the stuff prebent.
as for local patch jobs such as the floorpans, and what not, try using a die grinder with a "rol-loc" zip disc. ( i think that is right???) you actually have better control over your cuts using one of those. a bodymans hammer and a dolly (put the dolly in a vise) and that makes a poorman's english wheel. this will help you to shape the metal and get the proper contour before the final fitment. which in turn also gives you a better seam to weld. the more prep work you do before welding, the easier it is.
also going back to the die grinder part, I usually use tape (just regular 3M masking tape.) to mark out the line you want cut. WAY easier.
just my 2 cents.
keep up the great job,
WE WANT MORE PICS!! LOL LOL :D
1966 F-100. Family heirloom. (the bale hauler)
2007 can-am outlander 800XT
2007 2500 dodge c/c s/b hemi. (JUNK!!!!)
2003 F-350 8" BDS lift. 6.0L-- BIG & FAST!-- looking for an automatic trans.
sgart80
Post by sgart80 »
Anthony, I've been watching your build thread, and a lot of the others too, it’s nice to see what people are getting done. I have been planning on using the walmart bed-liner on the underside of the cab, I think it's a great idea (thanks for that by the way). I'm planning on using it on the inner fenders too. My patches may look ok in the pictures, but the pictures lie, I was very disappointed in my workmanship. The panels were crooked and I didn’t grind any of the welds to be flush, it was all very hurried and sloppy. I have to agree that the primer did look nice, I was happy to have the underside all one color, but I just couldn’t shake the feeling that I was going to be driving down the road some day, and I was going to hit the brakes and the front cab mounts were just going to collapse because I didn’t have proper penetration in my welds. In two more months and I’ll have had my truck for two and a half years. I started slow. I hope the cab won’t take me an eternity. I agree that pictures are an inspiration, I really enjoy watching everyone progress. I’ll try to keep updating when I get things accomplished.
jammck66, thanks for all of the advice, I especially like the tip about using the vice to hold my dolly, I’ll have to try that out. I agree with the patch panel being easier, I’ll pursue that route with anything that that I can’t fabricate to my liking. I’ve been using the heck out of my die grinder and angle grinders. What does the masking tape help do? I usually just mark the piece I want to cut with a permanent marker, you can see some of the blue marker lines in the pictures.
I spent 4 hours in the garage last night, I was in a zone, everything I bent seemed to go pretty well, I hope I don’t jinx myself. I cut out and bent three different pieces and lined them up, I still need to trim on the patches in the bottom picture, but I was ecstatic to see that the piece in the top picture lines up so well and with an acceptable gap that I should be able to fill with the welder. I guess a little patience paid off, the I guess the first time round was good practice too.
[albumimg]6995[/albumimg]
[albumimg]6996[/albumimg]
Anthony
Post by Anthony »
:thumright: I am going to enjoy watching your build.... Keep up the excellent work and if you have questions, just ask, We all like jumping in.... :roll: ...
Anthony
sgart80
Post by sgart80 »
I worked on the cab last night for about six hours. I was working so intently I almost forgot to quit for the night. The auto darkening helmet worked great. It was an eerie feeling the first time I went to put down a weld, but the shade closed instantaneously and the helmet functioned flawlessly. There isn’t much more to see from previous posts, except maybe some spot welds. I have to finish up the gaps in a few places, but here’s how I left I last night:
[albumimg]7003[/albumimg]
[albumimg]7004[/albumimg]
Spot welds on cab floor, I only burned through once.
[albumimg]7005[/albumimg]
Ford blue blood
Post by Ford blue blood »
squart80 keep on plugging away. One thing I learned years ago was you can put a butt load of material on the garage floor for the cost of one hours labor at a shop. Best part of making mistakes and going back to fix them is that lesson is never forgotten! There are many of use that started where you are and you are doing well....keep on keeping on!
Many great Fords,
sgart80
Post by sgart80 »
:D it was 68 degrees and sunny Saturday, so I worked on the truck all day. I finally got around to painting the rear axle center section:
[albumimg]7030[/albumimg]
I have the passenger side floor in, I still have to finish up some small stuff and reattach the cab mount, but it won't be long before I rip out the driver’s side for its rework.:dancing:
[albumimg]7031[/albumimg]
[albumimg]7032[/albumimg]
and thanks again for all of the positive feedback and comments.
Can I give you a hint?
On your lower kick panel where it attaches to the channel piece at the very bottom - put some good rosette welds there. I had to redo mine in that area because the weight of the body on the mount made it bend where the cab mount attaches - after it started to move it just ripped itself apart. Had to redo the whole thing. While you are at it anywhere in that area where 2 pieces are flat to each other I'd rosette weld it. You will be glad you did.
